Old 07-07-2015, 10:48 AM   #1
Opinion on which truck???
Hello All,
I am writing to get your opinion on a couple trucks that I have in mind. At a local GM dealer, they have the following trucks:
2007 Classic Silverado 2500HD CC D/A - 78,000 miles - asking $32,998
2015 Silverado 2500HD CC 6.0L with 4.10 rear end - 16,000 miles - asking $37,998
I currently own a 32ft SOB travel trailer that weighs in at about 8000 lbs loaded. I currently pull with a 2007 NBS Silverado 2500HD CC 6.0L 3.73 rear end. I have been looking quite seriously into purchasing a 2016 Wildcat 312BHX in the near future. This looks to be the perfect trailer for my family.
I am torn between the diesel and the gas truck. Both are in mint condition. The majority of the towing that I do is in Wisconsin, with the exception of two pulls to the UP of Michigan every year. Each one of these pulls averages about 4.5 to 5 hours.
Also, I do not use my truck as a daily driver. I only put about 4,000 to 5,000 miles on my truck a year, and most of that is pulling my travel trailer.
I know this is a broad question, but anyone have any opinions on either truck? Things I might want to watch out for?
I don't want to really get into the gas vs diesel debate, but just more wondering if there is specifics about each of these trucks that people do like and don't like. Even thought the 2015 is a gas motor, it is very appealing to me with such low miles on it.
Thanks in advance.
JeremyN is offline   Reply With Quote
Old 07-07-2015, 10:54 AM   #2
OntarioFireFighter's Avatar
If nothing else, 5 grand, for a truck that's got 1/5 the miles, and is 8 years newer, seems like a no brainer to me...
I'm a Ford guy, so can't speak specifically to either truck you're looking at, but a friend of mine pulls a good size fiver with a 2012 GMC 2500HD gasser, and has no issues.
I don't think either would be a bad choice, but for the price, and all other things being equal; I'd go with the newer one, myself...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 07-08-2015, 05:13 AM   #3
jerry226's Avatar
I bought a 2015 Silverado 6.0 410 rear end 6 speed transmission to pull my 35 ft 5th wheel that weights 1400+ loaded. It does a great job and has plenty of hp. I pull on flat ground and usually 500 mi trips at most. If I was a full timer and pulling in the mountains I would get a diesel because of the torque. What you are doing the gas would fit your need real good. My 2 cents.
jerry226 is offline   Reply With Quote
Old 07-08-2015, 06:42 AM   #4
TURBS's Avatar
2015 !
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-08-2015, 06:49 AM   #5
RSchleder's Avatar
I agree----no brainer, buy the newer truck!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-08-2015, 07:00 AM   #6
Georgia Frog Rally 2018
aceinspp's Avatar
I'd go with the 15. Also you will be getting a warranty with the 15. I have the 2015 3/4 ton Chevy with the 6.0 and 4.10 gears and like you I use it for mostly towing and about 5000 miles a year is all I put on it. I get 8 MPH towing my 35 ft 9000# V-lite. Does great job for what I use mine for. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-08-2015, 07:02 AM   #7
In 2011, GM updated the HD trucks. Main difference is the frame in 2011+ is a stronger fully boxed frame. The pre 2011 trucks had a combination of C-channel and box frame. The 2011+ CC short box 2500s have a GVW of 10,000 lbs while earlier trucks had a 9,200lb GVW. I also believe the 2011+ got an upgrade in suspension components and brakes.
Also the pre 2011 had a 26 gallon fuel tank on the crew cab short box, while the post 2011 have a 36 gallon tank on the short boxes. Long boxes are slightly larger in both cases the 11+ are still significantly larger
I would go with the 8 year newer truck with the lower miles for only 5 thousand more, if the gas engine is not an issue for you. Also, the new interior on the 2015 is, in my opinion, better than the 07.
2015.5 GMC 3500HD SLT SRW CC Z71 D/A
2014 Silverback 29IK
honker is offline   Reply With Quote
Old 07-08-2015, 08:20 AM   #8
KenHwy61's Avatar
For the money you are looking to spend on the 2015 gasser, I would wait for a good deal on a gently used 2011 or later Duramax. You will get a better towing experience and it will hold its value much better.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 07-08-2015, 08:26 AM   #9
jtstromsburg's Avatar
I'm different I guess, but I would keep looking. I bought an 06(sans truck as the classic 07 your are looking at) for just over $20k this winter, and its a 3500 dually 4x4 loaded. 06-7 had the lbz duramax, and from all ive read, it's the best duramax made. Before all the added emissions stuff, 6 speed Allison, and proven performance ands longevity. If you can find a better deal on an 07, I'd lean towards the diesel. But not at that price. I went from a f250 v10 to my 3500 duramax and love it! No more babying it on the hills. Just set the cruise and go.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-08-2015, 08:34 AM   #10
Ddubya's Avatar
I just bought a 2013 2500hd with diesel for $32,000 only 56000 miles.
Ddubya is offline   Reply With Quote
truck
