10-05-2015, 06:59 AM
Options for besides Firestone Air Bags
I have looked at trying to stiffen the suspension on my truck. I like the Firestone ride rite air bags and the load lifter 5000. What are other GOOD options are there for maybe less cost?
10-05-2015, 07:13 AM
I put a set of Airlift 1000 in my truck this summer and they seem to work good so far, I think I paid $80 for them. fairly easy to install, they have a video on youtube showing how. You can add a air compressor to your vehicle or just put air in with a regular air compressor, I chose a portable compressor I already had for mine. Not sure if this will help but hope it gave another option.
Think about things before you do them make life easier not harder.
10-05-2015, 07:19 AM
Not an alternative but a positive... I got the Load Lifter 5000 off amazon about 18 months ago. Excellent choice for me. At the time they were running a $50 rebate special and I think I recall paying a little over $200. I got a local mechanic to install them and he reported they fit like a glove. Took him an hour to install using his lift. I run 25# in them and only ran the air lines to the rear by the bumper. I have to air them up about once every 4-5 months as they lose a little pressure in that time.
The long rear overhang on my van required me to get something to keep the tail from loading down and these fit the bill perfectly.
2014 Shamrock 183
10-05-2015, 08:16 AM
Maybe something like this?
2018 Forester 3011 DS
10-05-2015, 11:33 AM
take a look at the Roadmaster Active Suspension.
it all depends what you have now and what you are towing, but I put this on for my previous TT.
Roadmaster Active Suspension Kits | Helper Springs | Overload Springs
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
10-05-2015, 11:35 AM
I had the Aerolift bags on my last van, and while they worked fine, it was a bother to adjust the air in them - should have gone with the onboard system.
Just recently installed Roadmaster Active Suspension Kits | Helper Springs | Overload Springson my present van. Great results so far.
10-05-2015, 11:40 AM
What kind of truck? Do you want the ride to be adjustable? Do you have a consistent load in the rear? They are many options available.
Happy Camping!
2012 Ram 1500 5.7L 3.92
Airlift 1000
2015 2809W WindJammer
Husky Centerline WDH
10-05-2015, 12:10 PM
Stiffer ride
Timbren springs stiffer when loaded easy to install less than a hour for the total job anybody can install them without a jack cost is low
10-05-2015, 12:52 PM
I had a RAM 1500 and put Airlift 1000 in the coils. I purchased them on-line for about $80 with free shipping. I had the air valves installed on either side of my license plates. Easy to inflate and deflate. What a difference in towing the 5th wheel. Hardly knew it was behind me. Looking to do the same with my F150.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
10-05-2015, 02:03 PM
not a sales person for RV upgrades but they have several options in the things you are looking for.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
10-05-2015, 04:31 PM
We have a 2015 Ford F250 we added Timbrens on to add a little support. We are putting a large load on this truck and not only were they SUPER easy(even for a female) to put on but they work great.
10-05-2015, 04:54 PM
Over the years, I’ve tried helper springs, an extra leaf in the overload springs and air bags. The air bags worked the best. I installed LoadLifter 5000 air bags from Air Lift in my current F350 to haul around my slide-in pickup camper. It worked great. I’ve replaced that Lance camper with a Wildcat 5th wheel trailer and found I still use the air bags to level the truck. My headlight beams are where they belong and the ride is comfortable when towing the 5th wheel. I have about 20-25 pounds of air pressure in them when loaded and go down to around #5 pounds when driving without the trailer for any amount of time. I use a small 12V air compressor to make the adjustments with the Schrader valves mounted on a sheet metal lip in the wheel wells.
The air bag installation was easiest in my last truck as there was no drilling. The air bags made it a little more work to install the frame-mounted 5th wheel hitch rails but again, no drilling in the frame, so it worked out well.
The biggest advantage to air bags is the ability to get your TV back to level when hauling the load, which means the headlights point where they belong for night driving. The other methods I used to supplement the truck’s suspension couldn’t do that. To me, that was a pig plus and why I recommend air bags over other methods.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
10-05-2015, 08:02 PM
Originally Posted by Cathcartww
Connected both together add air one spot haven't had a problem yet.
10-06-2015, 09:28 AM
Dutchtexan
Air bags
You might want to consider the "Torklift Quick Disconnect StableLoad" I added this to my 1/2 ton truck when I got my TT and helped even more to take some of the relieve off of my AirLift Air Bag system I already had. This site
Torklift Quick Disconnect StableLoad will show how it works and helps with the air bags. Super easy to install, hope this helps.
TT: 2014 Forest River 27VRL Super-V
V-nose TT w/Rear Living area, 2 slides, Equal-I-zer 4 point hitch #10000
TV: 2011 Chevy Silverado Z71 Extended Cab AirLift 1000 w/WirelessAIR
10-06-2015, 04:19 PM
Thanks. I went ahead and ordered the load lifter 5000.
10-06-2015, 04:47 PM
Originally Posted by RVBikers
X2
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017 98 days camping 2018
94 days camping 2019 49 days camping 2020
10-07-2015, 08:55 AM
I had the Firestone Ride Rite airbags put on my F250. Wish I would have added the onboard compressor, but for now I just air them up at the rear bumper. Love being able to adjust the ride height of the 5th wheel, more comfortable ride. Since my truck has a factory off road package, the ride was already stiff, but with the bags on it, the ride is a little stiffer without a load on it, because yo have to maintain at least 5 psi all the time.
2015 Ford F-250 SuperCrew 6.7L w/Firestone Ride Rite Air Bags
2015 Forest River Wildcat Extra Lite 295RSX
Days Camped 2015 - 37
10-07-2015, 02:21 PM
I installed the Air Lift 5000 bags in my F250 SRW CC three years ago and have been very pleased with their performance. My truck and camper are always level to ensure brake performance in addition to numerous other concerns. I chose to run the air lines through the back bumper next to the license plate with a separate valve for each line. When I am hitched to the camper I keep 55# of air in each bag to support a 2200# load. The bags are designed to support 40# of load for each pound of air in the bag. Having separate air lines also allows me to vary the air pressure on each side if needed to support the weight in my 37' Columbus 5th wheel. If you install a washer/dryer this changes the load requirement for each side.
I always check the air in my camper tires and truck when I hook up so it is no hassle with adding air. The 5000 design includes a jounce bumper inside the air bag which protects the bag if a leak should occur in a line or the bags are deflated. When researching the various air bags prior to making a decision to buy I talked to a Firestone "regional rep" and was told the primary cause for air bag failure is the bag tearing when they are deflated. The Air Lift 5000 bags are guaranteed for life. When you install the bags be sure the heat shield is located properly to prevent damage to the bag next to the exhaust particularly if you have a diesel because the exhaust pipe can get very hot. I am sure you will be pleased with the Air Lift 5000 bags.
10-07-2015, 10:56 PM
You did good and install was not hard. Hardest part was dealing with the existing bumper stop on the frame. I've had em since 2009 and appreciate the benefit every time I use them. Once you let air out, when unloaded, you get your original ride back.
10-08-2015, 07:27 AM
Kelderman
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
