Old 10-05-2015, 04:31 PM   #11
Originally Posted by Boso View Post
Timbren springs stiffer when loaded easy to install less than a hour for the total job anybody can install them without a jack cost is low
We have a 2015 Ford F250 we added Timbrens on to add a little support. We are putting a large load on this truck and not only were they SUPER easy(even for a female) to put on but they work great.
tammyK. is offline   Reply With Quote
Old 10-05-2015, 04:54 PM   #12
TGR
TGR's Avatar
Over the years, I’ve tried helper springs, an extra leaf in the overload springs and air bags. The air bags worked the best. I installed LoadLifter 5000 air bags from Air Lift in my current F350 to haul around my slide-in pickup camper. It worked great. I’ve replaced that Lance camper with a Wildcat 5th wheel trailer and found I still use the air bags to level the truck. My headlight beams are where they belong and the ride is comfortable when towing the 5th wheel. I have about 20-25 pounds of air pressure in them when loaded and go down to around #5 pounds when driving without the trailer for any amount of time. I use a small 12V air compressor to make the adjustments with the Schrader valves mounted on a sheet metal lip in the wheel wells.
The air bag installation was easiest in my last truck as there was no drilling. The air bags made it a little more work to install the frame-mounted 5th wheel hitch rails but again, no drilling in the frame, so it worked out well.
The biggest advantage to air bags is the ability to get your TV back to level when hauling the load, which means the headlights point where they belong for night driving. The other methods I used to supplement the truck’s suspension couldn’t do that. To me, that was a pig plus and why I recommend air bags over other methods.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 10-05-2015, 08:02 PM   #13
mark0224's Avatar
Originally Posted by Cathcartww View Post
I had the Aerolift bags on my last van, and while they worked fine, it was a bother to adjust the air in them - should have gone with the onboard system.
Just recently installedRoadmaster Active Suspension Kits | Helper Springs | Overload Springson my present van. Great results so far.
Connected both together add air one spot haven't had a problem yet.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-06-2015, 09:28 AM   #14
Dutchtexan
Dutchtexan's Avatar
Air bags
You might want to consider the "Torklift Quick Disconnect StableLoad" I added this to my 1/2 ton truck when I got my TT and helped even more to take some of the relieve off of my AirLift Air Bag system I already had. This site
Torklift Quick Disconnect StableLoad will show how it works and helps with the air bags. Super easy to install, hope this helps.
TT: 2014 Forest River 27VRL Super-V
V-nose TT w/Rear Living area, 2 slides, Equal-I-zer 4 point hitch #10000
TV: 2011 Chevy Silverado Z71 Extended Cab AirLift 1000 w/WirelessAIR
Dutchtexan is offline   Reply With Quote
Old 10-06-2015, 04:19 PM   #15
Thanks. I went ahead and ordered the load lifter 5000.
Rhoadzie is offline   Reply With Quote
Old 10-06-2015, 04:47 PM   #16
Wayne Joan's Avatar
Originally Posted by RVBikers View Post
take a look at the Roadmaster Active Suspension.
it all depends what you have now and what you are towing, but I put this on for my previous TT.
X2
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
86 days camping 2018
Wayne Joan is offline   Reply With Quote
Old 10-07-2015, 08:55 AM   #17
I had the Firestone Ride Rite airbags put on my F250. Wish I would have added the onboard compressor, but for now I just air them up at the rear bumper. Love being able to adjust the ride height of the 5th wheel, more comfortable ride. Since my truck has a factory off road package, the ride was already stiff, but with the bags on it, the ride is a little stiffer without a load on it, because yo have to maintain at least 5 psi all the time.
2015 Ford F-250 SuperCrew 6.7L w/Firestone Ride Rite Air Bags
2015 Forest River Wildcat Extra Lite 295RSX
Days Camped 2015 - 37
jkrise is offline   Reply With Quote
Old 10-07-2015, 02:21 PM   #18
I installed the Air Lift 5000 bags in my F250 SRW CC three years ago and have been very pleased with their performance. My truck and camper are always level to ensure brake performance in addition to numerous other concerns. I chose to run the air lines through the back bumper next to the license plate with a separate valve for each line. When I am hitched to the camper I keep 55# of air in each bag to support a 2200# load. The bags are designed to support 40# of load for each pound of air in the bag. Having separate air lines also allows me to vary the air pressure on each side if needed to support the weight in my 37' Columbus 5th wheel. If you install a washer/dryer this changes the load requirement for each side.
I always check the air in my camper tires and truck when I hook up so it is no hassle with adding air. The 5000 design includes a jounce bumper inside the air bag which protects the bag if a leak should occur in a line or the bags are deflated. When researching the various air bags prior to making a decision to buy I talked to a Firestone "regional rep" and was told the primary cause for air bag failure is the bag tearing when they are deflated. The Air Lift 5000 bags are guaranteed for life. When you install the bags be sure the heat shield is located properly to prevent damage to the bag next to the exhaust particularly if you have a diesel because the exhaust pipe can get very hot. I am sure you will be pleased with the Air Lift 5000 bags.
10Penny is offline   Reply With Quote
Old 10-07-2015, 10:56 PM   #19
dcheatwood's Avatar
You did good and install was not hard. Hardest part was dealing with the existing bumper stop on the frame. I've had em since 2009 and appreciate the benefit every time I use them. Once you let air out, when unloaded, you get your original ride back.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 10-08-2015, 07:27 AM   #20
Kenny kustom's Avatar
Kelderman
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
air bags
