Old 12-10-2009, 10:39 PM   #1
powerboatr's Avatar
our new Toad hauler
After many months of reading and watching
i decided no tow bar or dollie was going to make me happy
I have to be able to back up, it has to be a Navy thing
so after much looking and leaning i found one for us.
it might not be the best deal for smaller cg's but i have a solution for tight places. we dont always take the car with us anyways,
but this baby will check off one more box for our Alaska trip
ID:	2030   Click image for larger version
ID:	2031   Click image for larger version
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 12-10-2009, 11:41 PM   #2
IS that really called a "Toad"? If it is then a made a crack about that in a earlier post i thought it was a misspelling
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 12-10-2009, 11:59 PM   #3
Where are the loading ramps? Didn't see them stored in the trailer anywhere? If not there, might want to get some, and figure a way to haul them also. Nice looking trailer, but keep in mind that metal floor will be very slick when wet. Metal ramps will be too. I would look in to adding some side rails, especially if used only for the purpose of hauling one vehicle. Also make sure you take a test pull around the block and up to highway speed. May not need to load all the way on the front of the trailer, to adjust tongue weight.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 12-11-2009, 01:12 AM   #4
powerboatr's Avatar
ramps are in the rear left side pocket behind the fenders,
i have thought about non skidding the deck to prevent by bouncing off the thing
they slide in and are clipped in place, i need to replace the pin clips with padlocks to prevent an unwarranted departure
as for the tongue
i have a 30x64 tool box going down first on the forward floor
then the edge it has 111" WB and measured out.....it should sit with around 75%-80% on the wheels, but i will go do a drive by at the scales to set the final location
for holding the edge down i ordered some E-track and wheel straps, hopefully they come in soon,
the empty trailer looks heavy....but my svelte 229 lbs standing on the rear deck, will lift the tongue off the ground
Old 12-11-2009, 07:46 AM   #5
My friend has one just like that one, and he's pulled many cars with his, and it pulls great. I have used it twice myself, and not had any problems. It is however pretty wide- wider than the vehicle towing it, usually. Randy
Old 12-11-2009, 08:46 PM   #6
milzat's Avatar
A "toad" is a play on words for a "towed vehicle."
powerboat, that's a fine looking car hauler.
milzat is offline   Reply With Quote
Old 12-11-2009, 09:46 PM   #7
Dave_Monica's Avatar
I have a similiar trailer for my drag car. I suggest that you fabricate a piece of 3 x 3 angle with mounting tabs and bolt to the trailer deck at the location of the driver's side front tire. That way went you drive/winch the vehicle onto the trailer up to the bolted-on stop. The real trick is to determine the right location of the vehicle on the trailer for best towing characteristics...a little trial and error before you bolt the stop in place.
Dave
Old 12-11-2009, 09:59 PM   #8
Hey 08flagvlite;
I've meant to ask you for a while about your signature...
'06 Ram 1500 Hemi...Check,
'04 Durango Limited Hemi... Double Check,
'72 Mustang Mach One 351 cj ????
Dave
Old 12-11-2009, 10:10 PM   #9
powerboatr's Avatar
Dave
Dave
thanks for the great idea
I have the e-tracks coming soon, i can easily add a wheel stop to them, thanks again for the great EASY idea, i hadn't even thought about a wheel stop
Old 12-12-2009, 08:52 AM   #10
MtnGuy's Avatar
I have also heard Towed On A Dolly, and TOw All (wheels) Down, which is similar to FROG (Four (wheels) Running On Ground).
