Old 08-11-2016, 06:01 AM   #21
Originally Posted by Alex.mcintosh40 View Post
May I ask what the black ring or collar is around there mine does not have that kind of curious
I don't have that ring either. Does that make it easier to line up/set down on the ball?
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Nights camped 2016-43
Nights camped 2017-2....so far
Electra glide is offline   Reply With Quote
Old 08-11-2016, 07:13 AM   #22
ccsvolsfan's Avatar
It is a funnel like devise. You may also need a new ball. The two are around $90. Well worth it. New models come with it.
ccsvolsfan is offline   Reply With Quote
Old 08-11-2016, 02:14 PM   #23
head gamez's Avatar
Yep. Bought mine on Amazon a while back. Well worth the money as it gives you a little larger margin of error when backing under it.
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 08-12-2016, 08:16 PM   #24
Okay I tried to do the 90 and it didn't work. Here's my video. https://youtu.be/hNaL58c6JKg
2016 Vengeance 320A
Old 08-13-2016, 12:09 AM   #25
Blog: RVroadtripper.com
hbillsmith's Avatar
I watched your video and it looks like you have the 5.5ft bed crew cab (mine is 6.6ft double cab). You should reverse the kingpin adapter to gain 8" more clearance. If 4" is enough then also use your 4" offset ball to make it net 4" instead.
Check out my video
Reverse Mount Explained
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 08-13-2016, 10:45 AM   #26
Now a "Top Member"
EdJunior's Avatar
That looks like more of a front cap design issue. It looks like that "scoop" design took up at least 6 inches of possible turn radius. It looks neat, but doesn't do you any favors for that 90 degree turn.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 08-13-2016, 11:42 AM   #27
I think I have the maximum length possible.
ID:	117102   Click image for larger version
ID:	117103   Click image for larger version
2016 Vengeance 320A
Old 08-13-2016, 11:49 AM   #28
hbillsmith's Avatar
Thanks for posting the closeup. I see now you do have the maximum length. Suggest you add the Reese 4" offset ball then. That will give you another 4" back.
Also, you may not be aware that Andersen made a slight change to the design and they now ship what many refer to as the "Ultimate II". It's easy to tell the difference. Yours has a single triangle logo plate that's at the front of the frame and faces the cab when your hitch is installed. The Ultimate II has two triangle plates, one on each side of the frame when installed. The new design includes the funnel ring for easier hitching. But what's most relevant for you is that their design change also moved the top ball about an inch or two further away from the cab.
The Andersen Ultimate is sold with a lifetime warranty. I suggest you contact Jason at Andersen and have him look at your video. Andersen has been willing in the past to swap out for the newer model as a warranty exchange. You may find that a combination of the new design plus a Reese offset ball is all you need to get the 90deg turn.
Old 08-14-2016, 08:49 PM   #29
I use an Andersen Aluminum Ultimate Connection, Andersen Camper leveler, and Andersen Rapid Jack. Andersen makes great products.
menekaunee is offline   Reply With Quote
Old 08-15-2016, 09:59 PM   #30
Another option for a light weigh, empty bed hitch is the Reese Goosebox. It replaces your entire pin box and you only have the turnover ball in the bed. Lippert approved. It also has suspension and the height is adjustable with the standard pin box bolts and the air suspension fill.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 10 so far
DocGTO is offline   Reply With Quote
pullrite
