Old 04-18-2019, 09:37 PM   #1
Over inflate tires when towing?
Is it common practice to overinflate the tires of the tow vehicle when towing. I just noticed the other day when my tt was hooked up and it is still dry as we just got it out of storage my tires were looking pretty squishy. Their 1 yr old Michelin AT2’s that are properly inflated to normal everyday driving. Where would I find the max psi to fill the tires? I assume on the tire and I’m guessing this will help with control and gas mileage.
Olotti is offline   Reply With Quote
Old 04-18-2019, 09:41 PM   #2
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Max PSI is on the sidewall of the tire.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
A Loving wife
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 04-18-2019, 09:45 PM   #3
I have two stickers on the sides of the frame with the Max psi recommended for the trailer. Mine run 65 psi.
TheWolfPaq82 is offline   Reply With Quote
Old 04-18-2019, 09:47 PM   #4
Recently new!
Paulie1138's Avatar
I thought he was referring to his TV.
2001 Ford F-250 7.3
A Loving wife
Old 04-18-2019, 09:49 PM   #5
You may be right.
Old 04-18-2019, 09:50 PM   #6
Originally Posted by Olotti View Post
Is it common practice to overinflate the tires when towing. I just noticed the other day when my tt was hooked up and it is still dry as we just got it out of storage my tires were looking pretty squishy. Their 1 yr old Michelin AT2ís that are properly inflated to normal everyday driving. Where would I find the max psi to fill the tires? I assume on the tire and Iím guessing this will help with control and gas mileage.
You talking about your truck or your trailer ??
Old 04-18-2019, 09:51 PM   #7
dieselguy's Avatar
I'm thinking tow vehicle as well. You should have a sticker on your door frame or dig out your owners manual and go to the tire section for your recommended towing PSI. Check tire pressure in the morning before you drive it. You don't necessarily want to run the max PSI stated on the tire sidewall unless you like riding in a lumber wagon … go with your manual.
dieselguy is offline   Reply With Quote
Old 04-18-2019, 09:52 PM   #8
The sidewalk of the tire gives the recommended pressure.
I check mine before each trip.
I drive a truck, I check my tires every time I get out of the truck!
In 6 years i have had three tires going down.
I immediately plugged them, no more problems.
That is 10 tires, and well over a half million miles.
My friends that don't check them regularly destroy about 4 tires in the same time and mileage!
It's all about keeping the right amount of air in them!
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 04-18-2019, 09:57 PM   #9
Originally Posted by dieselguy View Post
I'm thinking tow vehicle as well. You should have a sticker on your door frame or dig out your owners manual and go to the tire section for your recommended towing PSI. Check tire pressure in the morning before you drive it. You don't necessarily want to run the max PSI stated on the tire sidewall unless you like riding in a lumber wagon Ö go with your manual.
Yes itís the truck tires Iím asking about.
Old 04-18-2019, 09:59 PM   #10
The truck.
tire, tires, towing
