Old 04-09-2013, 09:34 PM   #11
Professional Texan
TexasBob's Avatar
Originally Posted by wyo700 View Post
I am an ex mechanic but I am not really familiar with trailer brakes I did not have to work on many. I am sure they are not to complicated. I feel like I should know this but when you refer to coils is this the same as magnet. Thanks
Yes
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 04-09-2013, 09:43 PM   #12
wyo700's Avatar
Thank you
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-09-2013, 09:45 PM   #13
DDC
DDC's Avatar
They work like a solenoid, just think of it as a starter solenoid.best way to test would be disconnecting them one at a time and going through what you did before.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 04-09-2013, 10:19 PM   #14
wyo700's Avatar
Ok thank you. I'm sure I will get it figured out. I hope it's something obvious. Camper is only a year old cant imagine its something to major.
2013 Toyota Tundra
Old 04-09-2013, 10:45 PM   #15
Is your truck new and your camper one you have been pulling with another TV? From your post it sounds like you bought a new truck and installed a P3. Is this right? If so, you must have been pulling your camper with another TV without a problem. Could it be you have a P3 defective out of the box? It does happen....
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 04-09-2013, 10:47 PM   #16
wyo700's Avatar
Yes you are exactly right. I had a Nissan Titan before and a different TBC. With my tundra I bought a new P3 for it.
2013 Toyota Tundra
Old 04-09-2013, 10:49 PM   #17
wyo700's Avatar
I kind of thought this maybe because I didn't have a problem before but my old tbc is nothing like this P3 I just figured the diagnostics this P3 has showed me I had a problem or that I was applying to much force to the brakes.
2013 Toyota Tundra
Old 04-09-2013, 11:03 PM   #18
wyo700's Avatar
I will tell you one other thing. When I was trying to do the first set up to turn it up till the brakes lock up then back it down. Well from my first initial set up I tried this and I could feel the brakes lock up hard and then they would completely cut out and it would give me the message. Could one magnet bad cause that to happen. It seemed odd to me.
2013 Toyota Tundra
Old 04-09-2013, 11:08 PM   #19
Maybe one brake but not all brakes. You said you had a pigtail made up? Did your Tundra have the tow package and the 7 pin connector already installed and all you had to do is plug the P3 harness into the under dash connector?
2016 Siverback 33IK
Old 04-09-2013, 11:13 PM   #20
The blue wire goes to all brakes. Checkout this diagram from e-trailer. http://www.etrailer.com/faq-wiring.aspx
It just seems strange your problem began with new truck and new controller. Maybe you need to suspect the controller or the wiring harness
2016 Siverback 33IK
