Old 04-11-2019, 06:36 PM   #1
Payload and tongue weight
In the near future we intend to upgrade from the Tundra (lousy payload) to a Ram 2500 with 3,380 lbs of payload. The wife is not crazy about 5th wheels for a variety of reasons so we will be staying with a TT. I understand pin weights but I was curious as to how much tongue weight a factory equipped HD truck is allowed. I see the numbers on the tech spec, about Wt Distributing Hitch - Max Trailer Wt. of 14,410 lbs but do I need to be concerned about a max tongue weight?
Tundra 2017 CrewMax
FR 2017 T2460 EVO
Andersen sway control
Cahriad is offline   Reply With Quote
Old 04-11-2019, 06:43 PM   #2
Prime Member
As long as your total payload including the trailer tongue weight does not exceed 3380lbs your good.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 04-11-2019, 06:58 PM   #3
Chief T's Avatar
I wish I had 3380 of payload; i'd be towing in the next millennia.
Safe and happy travels.
2017 Tracer Air 206
2012 GMC Sierra 1500 SLT 6.2l
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 4
Chief T is offline   Reply With Quote
Old 04-11-2019, 07:22 PM   #4
Multi-Slacker
What is your hitch receiver rated for? That is one possible maximum. Another is your rear axle rating? Unless you go for a truly massive trailer, you should be fine. Do the arithmetic anyway. 15% of GVWR yields a quick, conservative estimate.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is offline   Reply With Quote
Old 04-11-2019, 07:35 PM   #5
It should say on the hitch . 1,400 lbs seems to be close to a max with wdh
MR.M is offline   Reply With Quote
Old 04-11-2019, 07:43 PM   #6
Multi-Slacker
Blue Ox can go to 2000 lbs
Old 04-11-2019, 07:46 PM   #7
clarkbre's Avatar
As an example, the truck in my signature is rated to tow 12,200 and the max hitch rated tongue weight is 1250 with a WDH. If the trailer I'm towing has a 15% tongue weight at 1250, the trailer would only be 8,333 pounds. And, if it had an 11% tongue weight at 1250, the trailer could be 11,363
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 04-11-2019, 07:47 PM   #8
clarkbre's Avatar
Even with a factory hitch rating substantially less than that?
Old 04-12-2019, 05:21 AM   #9
BigH's Avatar
Yes, you need to be concerned about tongue weight as there is a max weight limit on the reciever...the truck also has a limit.
What year truck?
I nearly bought a 2018 Ram 2500. I remember a maxium tongue weight of 1800lbs with the factory class V receiver.
The HD Chevy factory class V receiver has a limit of 2000lbs tongue weight and doesn't require a WDH all they way up to the limit.
I don't remember the numbers on the Ford as I ruled that one out early on in the shopping process.
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 04-12-2019, 09:51 AM   #10
From what I could see in Googling, the RAM truck tongue weight is determined by the class of hitch it has on it. A class 5 hitch is rated at 1,800 lbs, which most likely would be your limit.
The chart for the RAM truck is: https://www.ramtrucks.com/BodyBuilde...ficationId=390
Wileykid is offline   Reply With Quote
tongue weight, weight
