Old 09-24-2014, 10:14 PM   #1
Payload capacity 2013 F250 diesel
I apologize for having to post this, but I'm confused. From searching the forum and the net, I believe the rated payload capacity for a 2013 F250 HD Platinum crew cab is around 2500lbs. I see a recent truck posted for sale, and there is a picture on the load rating sticker on the door panel, and indicates "weight of cargo and passengers should not exceed 1829". What am I missing in the 700lbs or so delta between the Ford's towing guide, and what is placed on the truck itself?
for what it's worth, I'm looking to tow a Lacrosse 329BHT, and the tong weight will easily get at or over 1,000 lbs.
marcindy is offline   Reply With Quote
Old 09-24-2014, 10:27 PM   #2
asquared's Avatar
The ratings on website are typically for the stripped down models. Every option on a vehicle adds weight that takes away from payload. With a door sticker of 1829 you will need to subtract the weight of all occupants, pets and cargo that will be in the truck when towing. I'm betting that could easily drop it below 1500.
That tt has a gvwr of 11280 lbs. You will more likely be somewhere around 10,000 lbs loaded. Ideal tongue weight is 13-15% of loaded tt weight. So now you are talking 1300-1500 lbs tongue weight. It could be more or less. With a tt that heavy, I would be looking at 1 ton trucks. The other thing to pay attention to is receiver ratings. Many trucks class V receivers max around 1500 lbs. I did recently learn that a short bed chevy (both 2500 and 3500) max receiver rating.g is 1500 lbs. For the same truck in a long bed the receiver beefed up to 2000 lbs max receiver ratings. Pay very close attention to all actual ratings on the exact truck you buy.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-24-2014, 11:49 PM   #3
ironj's Avatar
Your receiver on a 250 will be a class 5...with 2.5 inch shank and wd hitch its rated for 15k or so....
I have a lacrosse and tow around 10k loaded....
With my wife, kid, genny, and extra fuel in the bed I was over a few lbs last trip....
That said, truck towed More than fine all the way up colorado and even bear tooth....
If you opt for stock suspension you will get a noticeable sag at over 1000lb tongue....mine has air lit bags .
Love it so much im getting another one....a 2015 platinum DUALLY....(a 15k 5er th behind it)...
My advice...go 350....or put bags on the 250...they will tow the same
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 09-25-2014, 06:33 AM   #4
Incheon, S. Korea
BigBaron's Avatar
They are the same except a 4" spacer on the rear axle as opposed to a 2" on the 250, and an additional leaf spring.
Adjustable air bags will keep the smoother ride while allowing you to keep the truck level with load IMHO.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 09-25-2014, 06:40 AM   #5
If your going to mod it just to make it a 350 and have not purchased it yet, cheaper just to buy the 350. Everything stated in post 2 about the differance in book weight and what's on the door is spot on.
2015 Sandpiper 30IOK
2014 Ram 6.7 CC DRW
2006 Charger RT
X96mnn is offline   Reply With Quote
Old 09-25-2014, 09:05 AM   #6
Wow, I knew the actual payload was a little lower than spec, but didn't realize it was that far off. I was originally thinking of the f150 EB max payload, clearly that won't be enough.
Anyone know what the true payload for a GMC 2500 CC is approx, or is it about the same as F250?
Thx
Old 09-25-2014, 09:25 AM   #7
I believe the new chev 2500 is around 3760pds less options and such for the gas and 3500 for the diesel.
I looked at the fords, chev, and dodges back between April and July. My experiance looking at the door stickers the F250 was comparable to the 1500s in the other lines but added what appeared to be a much stronger frame, braking and drive train then the 1500 trucks. Really set up for doing more then what it appeared rated for. Long and short to compare I had to step up a model in the fords, the F350 compared to the chev and dodge 2500s while the F450 compared to the 3500s.
Again, brand I did not care all though a long time Dodge owner, this was about bang for my buck.
2014 Ram 6.7 CC DRW
2006 Charger RT
Old 09-25-2014, 09:46 AM   #8
Just remember each truck is different, there are plenty of F250's that have a better payload the an F350. It all depends how you option your truck, for example I owned a F250 XLT 4X2 SRW gasser that had a payload of 3533 lb. There were a lot of F350's in the same lot that didn't come close to that payload.
When you go looking at trucks, look in the door jam, that's where the payload for that specific truck will be. The more options the less payload.
2014 Silverback 33RL
2013 F350 DRW 6.7
jimmac28 is offline   Reply With Quote
Old 09-25-2014, 10:13 AM   #9
Jimmac is correct, I am only going off what the dealers had on their lots in my area. There was only two 250s where they had 6 350s. Comparing the similar optioned 250 to a 350 was not a lot in the differance, like $1500.
The only reason I went with the dodge, the dealer dropped 21k off the msrp and it became 3k less then the Ford f350 DRW. I almost still went with the Ford as the options for the 3k almost made it worth it, back up camera, upgraded interior, snow prep package and others. What bought would be called the farmers package, I went in with best price in mind as I will only be using it to haul my camper. If I was going to daily drive it, the F350 would be in my yard today.
The chevs were ruled out quick, I would need to order in comparable as they only had LTZ and I was looking to buy. The LTZ was about 10k more then the dodge but again the options made me drool a little.
2014 Ram 6.7 CC DRW
2006 Charger RT
Old 09-25-2014, 09:55 PM   #10
ironj, what hitch are you running?
We mostly dry camp in our HHT, and my 3 batteries, bikes, solar, water has my hitch at 1,000lbs +/- a little. I'm sure the 329 will jump up quickly depending on where the fresh water is located.
Amazing, I started out with the dealer telling me my Sequoia would tow the Lacrosse (which I knew it wouldn't), now we're up to 1 ton... lol
We spend ~60 nights a year in the trailer, so the 329 floor plan is really appealing
2013, f250, diesel
