Old 01-04-2019, 03:09 PM   #1
Chief T's Avatar
Payload Question
This may be silly, but I know every bit of payload capacity you have, the better.
Bought our new to us 12 GMC Sierra 6.2l in June. Payload sticker reads 1440 lbs. There is an after market tonneau cover on the back which is 30 lbs. So now I'm down to 1410 payload. Going through my files the other day I found the Carfax for the GMC. There is an entry that the running boards were removed on the pre-inspection delivery.
So, I guess the question is... with the side steps removed would the payload go back up to about 1440 lbs?
Safe and happy travels.
2017 Tracer Air 206
2012 GMC Sierra 1500 SLT 6.2l
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 4
Chief T is offline   Reply With Quote
Old 01-04-2019, 03:18 PM   #2
Head Rambler
Depending on whether the running boards were factory equipment. As in, put on at the factory before the truck was delivered to a dealer. If they were, then taking them off increasing the payload by the amount they weigh.
Gotta go campin!
Old 01-04-2019, 03:21 PM   #3
why on earth would it matter? if you are worried about 30 pounds you have bigger issues and should of bought a different truck. 30/1440 is roughly .02% of your payload
Kimber45 is offline   Reply With Quote
Old 01-04-2019, 03:25 PM   #4
Ejs4029's Avatar
I would just go weigh it to see exactly what payload you have left....Subtract the weight from your GVWR I think is 6,800 to 7,000lbs on your Sierra but check to make sure and there you go No more wondering.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 01-04-2019, 03:37 PM   #5
Yes, please explain
2rad4u is offline   Reply With Quote
Old 01-04-2019, 03:42 PM   #6
I have to explain the insignificance of 30 pounds? do you take the exact same stuff with you every time you leave with your camper? 30 pounds out of 1400 is nothing. I didn't take a piss the last time I left camping should I head to the scales to weight again?
Old 01-04-2019, 04:03 PM   #7
Grammar Pedant
67L48's Avatar
[...] and should of bought [...]
That's probably all you need to read of that response that implies the OP is the idiot in this equation.
Despite claims to the contrary, I don't believe it's a silly question -- different opinions are what a forum is about. I am one that thinks every pound matters and there's no harm in counting it up. I see more harm in the converse behavior -- using broad-brush strokes and assumptions.
As mentioned above, the payload from the factory is measured with factory equipment. So, whether you get a payload "give-back" upon the deletion of a piece of equipment is solely dependent on when that piece of equipment was added.
Newer trucks (past 15 years) are more apt to have factory running boards, but they don't necessarily have them.
Good luck.
Current RV: 2018 Rockwood Mini Lite 2504S
TV: 2005 F-150 King Ranch 4WD SCrew 5.4L Tow Package
Ordered TV (May): 2019 F-350 Lariat 4WD CCSB 6.7 PSD 3.55
67L48 is online now   Reply With Quote
Old 01-04-2019, 04:40 PM   #8
I don't believe it is a silly question either. Knowing where you are all the time may make a difference down the road. If you never keep track of weight added or taken away how would you really know where you are. Disappointed in some of the responses. Never a silly question, just bad answers,
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is offline   Reply With Quote
Old 01-04-2019, 04:45 PM   #9
cmac7203's Avatar
X2, that’s the best way to know...
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
cmac7203 is offline   Reply With Quote
Old 01-05-2019, 12:05 PM   #10
When in doubt, CAT Scale it and math is your friend.
Yeah, 30# isn't much overall BUT in my case, unlike the OP's curiousity, I'm running on the edge on my TV rear GAWR and TT GAWR. So I went through the TV & TT "with a fine tooth comb", carefully assessing & pulling out unused, thought nice to have, and might be needed items. Weighed all the items removed. Now, AFAIK, I'm back at or under weight ratings. I will CAT Scale it again when my travels take me near the scales.
2019 Cherokee Wolf Pup 16BHS
2008 Ford Explorer V6 w/tow package
Husky Centerline TS WDH 400-600# rated bars
2018 camped 16 nights at 4 GGs.
Boomerweps is offline   Reply With Quote
