Old 07-30-2015, 07:54 PM   #11
Was always told the pin should always be in front of the rear axle and NEVER behind it.
Old 07-30-2015, 08:25 PM   #12
JohnF's Avatar
[QUOTE=Herk7769;940191]Fonzie is actually answering the OPs question.
The OP was asking WHERE the pin weight rides on the truck as a percentage of the pin weight.
I would certainly "buy" any number more than 95% on the rear axle and less than 5% on the front.
It will vary by your actual pin location of course; my last scale showed 100% of the pin rode on the rear axle and 0% on the front. The previous weigh showed 100 pounds on the nose and 1350 on the rear (7% - 93%).[/QUOTE
Correct Lou. I am looking at a CC 36ckts and my 2015 f350 srw. The most concerning number at this point is the rear tire weight rating.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 07-30-2015, 08:56 PM   #13
Herk7769's Avatar
I am not sure anyone was suggesting that.
HAM CALLSIGN - KC3FFW
Old 07-30-2015, 09:18 PM   #14
Wasn't suggesting that, but it's about the only way adding pin wt would remove wt on the front axle, otherwise, at least theoretically, with the pin directly over or in front of the axle, any pin weight added will add to the front axle.
Old 07-31-2015, 01:48 AM   #15
Fulltime family RVer
Agreed. I realized afterwards that I only touched on the answer.
Any time the pin weight changes, the trucks front axle weight changes. It might not be much, but it has to change along with the pin weight.
I can believe that. But it must'nt be enough for the scale increments at CAT scales. I've done a few weighings where that amount hasn't changed.
Old 07-31-2015, 02:35 AM   #16
sail2liv's Avatar
Hmmmm 1/2 T TV light pin chuck chuck chuck put some weight on the pin for better tow, big trucks are always better
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 07-31-2015, 07:16 AM   #17
Learjet's Avatar
2,300 pin weight added 20lbs to front axle. Cat scale
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 07-31-2015, 08:00 AM   #18
I would imagine that your pin is very close to being on the center line of the axle.
Old 07-31-2015, 04:04 PM   #19
I wonder if you could put a slider on and stretch the camper out, would that make for a softer ride in the truck
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 08-01-2015, 02:05 AM   #20
2007 WildCat 32QBBS
05CrewDually's Avatar
Trucks I've been around all have the hitch set @ 2" in front of the rear axle centerline. It seems to be an industry standard.
One factor I didn't see mentioned yet is the wheelbase of the truck will change the % of weight transfered to the front axle. The shorter the wheel base, the MORE it will show on the front axle. This will show on the identical trucks except if one is a crew cab long bed Vs. a standard cab short bed.
05CrewDually is offline   Reply With Quote
tire, tires, weight
