Old 07-30-2015, 02:21 PM   #1
JohnF's Avatar
% pin weight to tires?
I donít have a 5th wheel camper yet but am wondering what % of the pin weight is applied to the rear axle/tires.....100%, 90%, etc.? I believe the 5th wheel hitches are mounted so the pin sits a few inches in front of the rear axle which is why I ask the question.
Thanks,
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 07-30-2015, 02:59 PM   #2
Fulltime family RVer
Fifth wheels typically carry 20% - 25% of their weight on the pin. Occasionally you will see fifth wheels designed with as low as 16% of pin weight (my model is included in that). I haven't heard of any fifth wheels above 25%.
You can actually get a best guess of loaded pin weights by taking the dry pin weight percentage and increasing it by a couple of percent (2-3%).
Very rarely do you see weight added or removed from the truck's front axle.
Old 07-30-2015, 03:28 PM   #3
fonzie's Avatar
It will be mostly about 98% of pin weight will be applied to towing vehicle rear axle....see thread below with actual weights at Cat scale for a fifth wheel....
New Sandpiper 365SAQ is here
Fonzie
Old 07-30-2015, 06:27 PM   #4
CWSWine's Avatar
Depends on the Model. - Factory specs on mine was 1945 pin width a 9900 lbs 5er. Loaded the 5er and the Cat scales says it weights 11,380 with pin weight of 2740 lbs at 24.1%. Below is the link to the cat scale weights.
Actual Weights - Fifth Wheel Weights from CAT Scales - Towing Planner
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 07-30-2015, 06:47 PM   #5
Herk7769's Avatar
Fonzie is actually answering the OPs question.
The OP was asking WHERE the pin weight rides on the truck as a percentage of the pin weight.
I would certainly "buy" any number more than 95% on the rear axle and less than 5% on the front.
It will vary by your actual pin location of course; my last scale showed 100% of the pin rode on the rear axle and 0% on the front. The previous weigh showed 100 pounds on the nose and 1350 on the rear (7% - 93%).
HAM CALLSIGN - KC3FFW
Old 07-30-2015, 06:47 PM   #6
...Very rarely do you see weight added or removed from the truck's front axle.
Any time the pin weight changes, the trucks front axle weight changes. It might not be much, but it has to change along with the pin weight.
Old 07-30-2015, 06:52 PM   #7
Originally Posted by Herk7769 View Post
It will vary by your actual pin of course; my last scale showed 100% of the pin rode on the rear axle and 0% on the front...
I don't doubt your figures, but the front axle scale is certainly questionable. If the pin is in front of the axle.
Old 07-30-2015, 07:01 PM   #8
CWSWine's Avatar
My front axle with 5er was 4980 and without the 5er hook up it was 4740 otherwise front axle increased by 240 lbs.
Old 07-30-2015, 07:04 PM   #9
Herk7769's Avatar
Having trouble uploading images for some reason...
"413 Request Entity Too Large" error ...
Old 07-30-2015, 07:24 PM   #10
Herk7769's Avatar
Hummm, a reboot did not fix my issue.
However I will try to explain what is going on best I can.
The pin load is a "point load" located 0 to 1 inch forward of the axle centerline (depending on make and model of truck) if the hitch is properly installed.
A hitch installed with the pin directly ON axle centerline will show zero to a few pounds on the front axle; A pin located further forward will transfer more of the pin load forward.
I tried to attach the manual for my hitch )which explains the reason they are not all installed "On Centerline") but am getting the same error.
tire, tires, weight
