Old 09-11-2015, 12:12 AM   #11
2007 WildCat 32QBBS
05CrewDually's Avatar
Ok, I got yah with the steel building.
Another thought, how about an air ride pinbox. Then all you would have to do is let the air out and it will lower. There's quite a bit of travel.
I could measure if you're interested. May not be the cheapest route but you would also greatly increase the ride as well. I won't own another 5er without it.
05CrewDually is offline   Reply With Quote
Old 09-11-2015, 07:29 AM   #12
Kenny kustom's Avatar
Swap blocks, don't remove the overload spring.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-11-2015, 08:11 AM   #13
MtnGuy's Avatar
Old 09-11-2015, 08:15 AM   #14
Don't forget, new u bolts as well!
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-13-2015, 09:38 AM   #15
Springs removed
OK! Springs are removed, but I had to (temporarily) reuse the U-bolts. New ones are in order. I'm out of town all this week--I hope to see if I have some more clearance on Saturday. I'll let y'all know...
Dr Steve is offline   Reply With Quote
Old 10-08-2015, 07:06 AM   #16
Update
Well, sort of. My trip out of town took longer than planned. I hitched up for the first time after removing the springs and pulled the fifth wheel out of the barn. I *think* I had a little more clearance but I'm unsure as I was by myself.
Headed to Bankhead National Forest today for a long weekend, then I'll let y'all know how my attempt at getting the fiver back under the roof goes. If I still have issues then I'll look at an air ride pinbox.
Steve and Renee
2015 Cedar Creek Silverback 29IK
2011 Ford F-350
Nights camped in 2015: 8
Old 10-08-2015, 08:20 AM   #17
I thought air ride pin boxes RAISE the front of the fifth?
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 10-08-2015, 08:26 AM   #18
Kelderman air ride is a major upgrade, but would accomplish what you need.
They 4 link the rear axle and replace the leaf springs with air bags.
Can drop the rear 6" by deflating the bags.
Pros:
Drop the rear to assist in loading anything into the bed
Air bag ride.
Cons:
It will run around $4k.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 10-08-2015, 08:58 AM   #19
AquaMan's Avatar
What is the situation of your carport? Any chance of raising it a couple inches? If it's a freestanding type, would think it would be fairly easy and cheap to raise.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-08-2015, 09:01 AM   #20
MtnGuy's Avatar
Pros:
Air bag ride.
Cons:
Kenny kustom, I guess the OP didn't see your post #12, or my post #4. Replacing the axle blocks would be a heck of a lot cheaper than the Kelderman air ride, if he only needs just a little clearance. I am still not sure how functional removing the spring leaf is gonna work out.
2011, f-350, fifth wheel, wheel
