Old 10-12-2015, 02:51 PM   #41
Originally Posted by IronCobra View Post
Bad news. Blocks were unlawfully removed from my storage...along with other stuff...... Sorry.
Man I hate to hear that. Minor bummer for me--I hope it wasn't too big a loss for you. Thanks for the info and offer to help!
Steve and Renee
2015 Cedar Creek Silverback 29IK
2011 Ford F-350
Nights camped in 2015: 8
Dr Steve is offline   Reply With Quote
Old 10-12-2015, 02:55 PM   #42
Originally Posted by Kenny kustom View Post
Block and U-Bolt Kits - Ford F250, F350
Pick your poison.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Thanks and cheers!
Steve and Renee
2011 Ford F-350
Old 10-12-2015, 02:56 PM   #43
Originally Posted by Iwannacamp View Post
I guess it wouldn't help or you have already done or it will raise the front somehow...but did you lower the 5er tires...temporarily of course
That would have been next...
Steve and Renee
2011 Ford F-350
Old 10-12-2015, 03:30 PM   #44
Please dont get those. For starters, they are only blocks. They do not have the Bump Stop brackets built onto them, so you are at risk of your bump stops not working if you hit a large pothole or bump. not safe.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 10-12-2015, 03:37 PM   #45
Thanks...can you tell me what to look for/maybe give a recommendation?
Steve and Renee
2011 Ford F-350
Old 10-12-2015, 03:42 PM   #46
see if this guy still has his for sale
Ford Powerstroke Diesel Forum
Old 10-12-2015, 03:59 PM   #47
Also, since your U-Bolts are long enough (and can be cut down if needed), you could simply buy the blocks from yoru local ford dealership or this site
2011 Ford F-250 Super Duty Leaf Spring Axle U-Bolt Spacer | FordParts.com
They should only cost about $45ea (perhaps less).
Be sure you ask for the blocks off of a 2011-2014 F250 that is the same cab/bed configuration as your truck.
The reason to stay in that year range is because Ford started to offer 4" blocks as an option for 15/16 models because some customers had complained about the rear of the truck slouching when loaded.
2011, f-350, fifth wheel, wheel
