09-09-2015, 09:41 PM
Please help with 2011 F-350LB: Remove auxiliary springs to lower fifth wheel nose?
Question up front, this post is kinda long: Will removing the auxiliary/helper springs from my 2011 F-350 allow for some 'squat' to lower the nose of my fifth wheel?
Well after doing some extended work away from home, I'm finally getting ready to take my new Silverback 29IK (bought last December) out for its first trip! It's been stored in a covered farm equipment 'carport' and looks like brand new!
Here's my dilemma: The top of my front AC clears the carport roof by less than an inch, even after taking some extreme measures to lower the front of the fiver.
Background: When I parked the fiver under there, I had a 2008 F-250 with air bags. With the bags at 5psi, the top of the front AC cleared the carport roof by about three inches. Tight, but doable. Long story short--the 250 is totaled, replaced by a 2011 F-350 long bed (bought away from home), also with bags and compressor.
I go to pull the fiver out today and would have hit the roof with the AC if not for my spotter! In order to get the fiver out of there I had to lower the hitch in the truck bed as far as it could go (actually leveled out the fiver--I have 6" clearance between trailer and top of the bed) AND reduce the truck's rear tire pressure from 80psi to 40. With minimum pressure in the bags, I got the trailer out of there with less than an inch to spare. Too tight.
The hitch is lowered as far as it will go. I don't want to raise the pin on the fiver because that would give me less than 6 inches clearance bed-to-trailer.
SO...I'm thinking I can remove the extra leaf (auxiliary/helper I think it's called) from the rear of my truck. With the air bags at minimum, the rear of the truck should squat more when the fiver is hitched, correct? Then once I have the fiver out of the carport I can make up for the lost springs with the air bags, much like I did with the F-250.
Has anyone done this, or have any other suggestions? This is a great pull-thru setup that I don't want to lose. I admit I didn't consider the difference in bed height/spring compression when I got this truck.
Thanks and cheers for getting to the end of this long post!
Steve and Renee
2015 Cedar Creek Silverback 29IK
2011 Ford F-350
Nights camped in 2015: 8
09-09-2015, 09:56 PM
Left Coast
If the overload springs are touching their bumpers, then yes.....if not, then only the thickness of the spring would be gained......would really depend on how hard (if) they're hitt'n the bumpers.
09-09-2015, 10:01 PM
I did this way back in 2001.Aux springs have been long gone!You say you have air bags but do you have a leveling valve on the rear suspension? I have the leveling valve and on board air so I actually can set my loaded ride hieght where I want it . My rear spring's only real function is to locate the rear axel.They do carry wieght,but if I deflate my rear bags completely and the truck is empty,it will sit perfectly level. When I add my 2500# pin wieght it will squat about 3 in. Then I set the level valve to bring the truck back up level.I have no idea how much air is in the bags because the valve controls this.When I unhook the trailer the truck will set about 3" higher in the rear,when the valve senses this it bleeds off air untill the truck is level.This is almost a pure air ride system just like is used on semi tractors,in fact it is IS the same leveling valve.The danger here is that I can overload the truck to the point it would start to bend something because the level valve always keeps it at the same ride hieght,regardless of how much wieght is in/on the box. You have to pay attention!
09-10-2015, 07:40 AM
The newer F350s come with a 4" (10 mm) block between the axle and springs. The 250s have a 2" block (5 mm). I have been reading about F350 owners switching out the 4" blocks for the F250 blocks.
Not sure if the 2011 models have the same setup or not.
09-10-2015, 07:58 AM
This
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-10-2015, 08:00 AM
Happy Keystone Owner
I did this on my 04 to clear my garage door with a topper. Leveled it out, too.
Anybody need some 4" blocks for their F250?
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
09-10-2015, 09:14 AM
Left Coast
The op said his set level as is, just needed door clearance....take over loads off for the clearance if that restricts using air bags to lower and raise to get it in and out.....or a sawsall to the header. Tak'n blocks out will cause the lowering of the front of truck, or it'll be a tail dragger. Would also have to add more threads to U bolts.
09-10-2015, 03:02 PM
2007 WildCat 32QBBS
Personally I'd look into extensions and raising the carport itself. The companies that sell these usually offer extensions. I don't know exactly what your carport is like but most are just sheet metal tubing legs.
09-10-2015, 08:58 PM
Thanks everyone, I'm going to try removing those aux springs. I'll have to level the truck manually with the compressor but that shouldn't be a problem.
My term 'carport' was kind of a misnomer...it's roughly 100 feet long and 40 feet wide, made of heavy steel beams and heavy-gauge metal roof. It's intended to cover farm implements--planters, plows, hay wagons, that sort of thing. I pull in from one side and park the fiver with roughly 5 feet of roof overhang at either end.
I'll let you all know how it goes!
Steve and Renee
2011 Ford F-350
09-10-2015, 08:59 PM
Left Coast
Please do.
09-11-2015, 12:12 AM
2007 WildCat 32QBBS
Ok, I got yah with the steel building.
Another thought, how about an air ride pinbox. Then all you would have to do is let the air out and it will lower. There's quite a bit of travel.
I could measure if you're interested. May not be the cheapest route but you would also greatly increase the ride as well. I won't own another 5er without it.
09-11-2015, 07:29 AM
Swap blocks, don't remove the overload spring.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
09-11-2015, 08:11 AM
09-11-2015, 08:15 AM
Don't forget, new u bolts as well!
2008 F350 CCSB V10
2016 Sabre 36QBOK
09-13-2015, 09:38 AM
Springs removed
OK! Springs are removed, but I had to (temporarily) reuse the U-bolts. New ones are in order. I'm out of town all this week--I hope to see if I have some more clearance on Saturday. I'll let y'all know...
10-08-2015, 07:06 AM
Update
Well, sort of. My trip out of town took longer than planned. I hitched up for the first time after removing the springs and pulled the fifth wheel out of the barn. I *think* I had a little more clearance but I'm unsure as I was by myself.
Headed to Bankhead National Forest today for a long weekend, then I'll let y'all know how my attempt at getting the fiver back under the roof goes. If I still have issues then I'll look at an air ride pinbox.
Steve and Renee
2011 Ford F-350
10-08-2015, 08:20 AM
I thought air ride pin boxes RAISE the front of the fifth?
2008 F350 CCSB V10
2016 Sabre 36QBOK
10-08-2015, 08:26 AM
Kelderman air ride is a major upgrade, but would accomplish what you need.
They 4 link the rear axle and replace the leaf springs with air bags.
Can drop the rear 6" by deflating the bags.
Pros:
Drop the rear to assist in loading anything into the bed
Air bag ride.
Cons:
It will run around $4k.
2008 F350 CCSB V10
2016 Sabre 36QBOK
10-08-2015, 08:58 AM
What is the situation of your carport? Any chance of raising it a couple inches? If it's a freestanding type, would think it would be fairly easy and cheap to raise.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
10-08-2015, 09:01 AM
Pros:
Air bag ride.
Cons:
Kenny kustom, I guess the OP didn't see your post #12, or my post #4. Replacing the axle blocks would be a heck of a lot cheaper than the Kelderman air ride, if he only needs just a little clearance. I am still not sure how functional removing the spring leaf is gonna work out.
