Old 01-07-2014, 04:30 PM   #11
puff's Avatar
I have seen this one debated to the bone on other sites. Your diesel works on combustion and the heat there in. I fail to understand why (if you can) you would not want to plug your truck in. A warmer engine/oil/fluids has less wear on start up, warms up faster, pisses your neighbors of less cause you can leave sooner, not to mention makes D.W. happy to get into a warm vehicle.
It comes down to a personal choice much like anything else but if you like your t.v. why not make it easier..??!!...just my .02 worth.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 01-07-2014, 04:35 PM   #12
TTNewbees's Avatar
Originally Posted by N3HCP View Post
My 2013 F-350 6.7L started right up at -3 this morning. The glow plugs might have been on a few seconds longer then usual, but otherwise a normal start.
Well it was -16 here yesterday a.m. Had the truck plugged in all night. Didn't help it, it's at ford getting fuel filters changed all the fuel is gelled up. The glow plug would fire and start normal but would not stay running cause it couldn't suck the pudding through the straw. 18,000 miles needed new fuel filters anyhow.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 01-07-2014, 04:49 PM   #13
Fulltime family RVer
Thanks for the input. I've honestly not used it before because it so rarely gets this cold here. AND- because I work from home, we don't often use the truck. It usually sites for 1-2 weeks at a time. My assumption was that she would use it today because it's in the driveway (due to furniture moving this past weekend) and it has remote start.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 01-07-2014, 04:53 PM   #14
golfmedik's Avatar
Remember guys, as well as plugging them in(preference) you need to be running an anit-gel in the fuel. It will start to gel around 15* here in the south but I know you northern guys have a little more additive in it from the refinery. I use Diesel Kleen's WHITE bottle for winter use around freezing and use twice as much as recommended sometimes. It will not hurt. Also, I use Diesel Kleen's GREY bottle at all other times. There are many out there, it's just I've always had good luck with DK to about -10 in the mountains.
Doug, what year is your Dodge? The newer ones have much better 'cold start' ability than the older ones.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 01-07-2014, 05:08 PM   #15
Capt. Mike's Avatar
It's 14* here which is colder than I'm used to dealing with. -10 windchill, but I assume that doesn't mean anything to the truck/engine.
I guess we'll find out shortly, but should I have plugged my truck's engine block heater (or whatever it is) in for my wife to use the truck in about a 1/2 hour?
Remember that "wind chill" is a made-up number that reflect what the combination of temperature and wind feels like to exposed skin, and how quickly that exposed skin can freeze...that is, get frost-bite. Your truck's engine is not subject to "wind chill." That being said, however, a moving vehicle is more likely to have fuel lines gel, but it is often a function of ice, snow and slush being thrown onto exposed fuel lines than actual "wind chill" that causes diesel fuel to gel...that and not having the correct winter blend and/or not having heated fuel filters.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 01-07-2014, 05:13 PM   #16
It's a 2012.
I've never added any additives nor have any idea what "blend" of fuel is in it. I didn't think Marylanders needed to worry about that kind of thing!
Old 01-07-2014, 05:44 PM   #17
golfmedik's Avatar
Plugging up the trucks will also help with reducing engine wear at start up as the oil flows better than when cold. I just like the fact that by plugging it up, it warms up faster thereby warming ME faster!
Old 01-07-2014, 06:06 PM   #18
Capt. Mike's Avatar
It's a 2012.
Doug,
Most suppliers start selling and delivering "winter blend" fuel to retail outlets in the fall, before winter hits. It may not get that cold in Maryland on a regular basis, but I suspect some blending is taking place, and you are buying it and may not even be aware of it.
Mike and Yvonne
Old 01-07-2014, 06:37 PM   #19
Engineer of Crazy Train
ChooChooMan74's Avatar
My little guy had a hard time starting today, but I do have 1 out of 4 glow plugs bad.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 01-13-2014, 04:52 PM   #20
After two cold nights (15 degrees) i noticed battery acid under my truck (07 chev.2500 HD Diesel) It looks like it came from the battery on the passenger side, this is a maintenance free battery, is this normal for this to happen. I plan to pull the battery and check for a leak in the case.
Gee Whiz is offline   Reply With Quote
truck
