01-07-2014, 02:20 PM
Always Learning
Plugging my truck in?
It's 14* here which is colder than I'm used to dealing with. -10 windchill, but I assume that doesn't mean anything to the truck/engine.
I guess we'll find out shortly, but should I have plugged my truck's engine block heater (or whatever it is) in for my wife to use the truck in about a 1/2 hour?
01-07-2014, 02:27 PM
Camper Less Camping
IMO...no need to plug in until outdoor actual temp drops below zero, otherwise you'll be fine, especially with a newer model oil burner
2013 Sabre 32RCTS-6 (sold)
01-07-2014, 02:40 PM
I plug it in when it's below 20 just to aid in less idle time warming up when I leave for work. I have mine on a digital timer to start about 3 hours before my normal work time. Windchill has no effect on this since that's a measurement of what it feels like.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
01-07-2014, 02:43 PM
I would agree and even at below zero the new ones are pretty good as long as your fuel is winter blend. Dealer here in Colorado put a you tube that shows one starting with ease at -11.
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
01-07-2014, 02:59 PM
Under 20 deg F for my Ford 6.0L. It will begrudgingly start on it's own way under 0 deg, but hence my moniker...'rattleNsmoke', so I give it a break....
01-07-2014, 03:05 PM
My 2013 F-350 6.7L started right up at -3 this morning. The glow plugs might have been on a few seconds longer then usual, but otherwise a normal start.
2020 Flagstaff 26FKBS pulled by a 2019 F-350 Diesel
01-07-2014, 03:16 PM
Having lived in MN for a bunch of my life, it was always a good idea to "plug in" when it got cold - below 25* usually, just to make it faster to get warm air off the heater core. Now that I am in FL, I would be plugging in when at 50*!! Well, maybe not. But Chewie is correct - wind chill is for the living, nothing else. Just like the Heat Index. But, for me, if they say it is whatever degrees, that is what I go by. Everybody "feels" it differently.
Brenda and John
Master Blaster of the Navy
01-07-2014, 03:18 PM
Anytime the wx fcst is for temps in the 20's, I plug it in the night before. This makes for easier starts and you get heat in the cabin sooner. I wrap the extension cord around the driver side mirror, lest I forget!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
01-07-2014, 03:42 PM
I plug mine in when I get home from work, when the temps are below freezing. Since we've had below 0 temps for several days now, I've also put my winter cover on.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
01-07-2014, 03:54 PM
Always Learning
Thanks y'all.
01-07-2014, 04:30 PM
I have seen this one debated to the bone on other sites. Your diesel works on combustion and the heat there in. I fail to understand why (if you can) you would not want to plug your truck in. A warmer engine/oil/fluids has less wear on start up, warms up faster, pisses your neighbors of less cause you can leave sooner, not to mention makes D.W. happy to get into a warm vehicle.
It comes down to a personal choice much like anything else but if you like your t.v. why not make it easier..??!!...just my .02 worth.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
01-07-2014, 04:35 PM
Well it was -16 here yesterday a.m. Had the truck plugged in all night. Didn't help it, it's at ford getting fuel filters changed all the fuel is gelled up. The glow plug would fire and start normal but would not stay running cause it couldn't suck the pudding through the straw. 18,000 miles needed new fuel filters anyhow.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
01-07-2014, 04:49 PM
Always Learning
Thanks for the input. I've honestly not used it before because it so rarely gets this cold here. AND- because I work from home, we don't often use the truck. It usually sites for 1-2 weeks at a time. My assumption was that she would use it today because it's in the driveway (due to furniture moving this past weekend) and it has remote start.
01-07-2014, 04:53 PM
Remember guys, as well as plugging them in(preference) you need to be running an anit-gel in the fuel. It will start to gel around 15* here in the south but I know you northern guys have a little more additive in it from the refinery. I use Diesel Kleen's WHITE bottle for winter use around freezing and use twice as much as recommended sometimes. It will not hurt. Also, I use Diesel Kleen's GREY bottle at all other times. There are many out there, it's just I've always had good luck with DK to about -10 in the mountains.
Doug, what year is your Dodge? The newer ones have much better 'cold start' ability than the older ones.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
01-07-2014, 05:08 PM
Remember that "wind chill" is a made-up number that reflect what the combination of temperature and wind feels like to exposed skin, and how quickly that exposed skin can freeze...that is, get frost-bite. Your truck's engine is not subject to "wind chill." That being said, however, a moving vehicle is more likely to have fuel lines gel, but it is often a function of ice, snow and slush being thrown onto exposed fuel lines than actual "wind chill" that causes diesel fuel to gel...that and not having the correct winter blend and/or not having heated fuel filters.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
01-07-2014, 05:13 PM
Always Learning
It's a 2012.
I've never added any additives nor have any idea what "blend" of fuel is in it. I didn't think Marylanders needed to worry about that kind of thing!
01-07-2014, 05:44 PM
Plugging up the trucks will also help with reducing engine wear at start up as the oil flows better than when cold. I just like the fact that by plugging it up, it warms up faster thereby warming ME faster!
01-07-2014, 06:06 PM
It's a 2012.
Doug,
Most suppliers start selling and delivering "winter blend" fuel to retail outlets in the fall, before winter hits. It may not get that cold in Maryland on a regular basis, but I suspect some blending is taking place, and you are buying it and may not even be aware of it.
Mike and Yvonne
01-07-2014, 06:37 PM
Engineer of Crazy Train
My little guy had a hard time starting today, but I do have 1 out of 4 glow plugs bad.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
01-13-2014, 04:52 PM
After two cold nights (15 degrees) i noticed battery acid under my truck (07 chev.2500 HD Diesel) It looks like it came from the battery on the passenger side, this is a maintenance free battery, is this normal for this to happen. I plan to pull the battery and check for a leak in the case.
