07-14-2011, 01:14 PM
Popping noise from chains on WD hitch
I have a Trunnion style WD Hitch, Reese PART NUMBER: 66541 with 800 lb spring bars. When ever I turn to the left or right, no matter how slight a turn, I hear a popping noise from the chains (like the chains are binding). The dealer who installed the hitch says this is normal. The noise wasn't there on the ride home after installation or the ride to my first trip. On the way home (120 mile roung trip) after I got off of the highway and making the first turn onto street, the popping noise started. I took to dealer, he observed this noise and said it was normal? Is this correct, am I damaging anything or voiding the warranty? My tounge weight of trailer trip ready is 804 pounds.
Bill
Bill & Cindy McKenna
Philadelphia PA
2011 Wildwood 26TBSS
2005 Ford F150 5.4 Triton V8 4x4 XLT
07-14-2011, 01:24 PM
Moderator
Bill
I don't have the same equipment but I will get noise when turning if my anti-swag is too snug or tight. I don't think mine is a popping noise but more like a grinding, squealing or contact noise depending on setting and turning ratio.
If you could post a picture then the more experience members can see how you have it set up.
Great choice for "Living within my means" and camping for one... 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab 16 Trips / 43 Nights / 1204 Miles
07-14-2011, 01:29 PM
Sorry, forgot to mention, I get this popping noise with or without the swaybar attached, I thought that was the problem but it wasn't. I read their tech tips page and I am supposed to put a drop of oil into the sockects (top and bottom), but nothing about the chains.
Bill
Philadelphia PA
07-14-2011, 01:32 PM
Moderator
I have the Reese 800 lb. bars attached to the Dual Cam system. If my system didn't do the Rice Crispy sounds when I turned, I would have to back and check out if the bars are still there.
If you are using the Dual Cam system, you can quiet it somewhat by using Vaseline where the bars meet the cams. Also, grease the spring bars at the assembly head, but do not use grease on the cams.....only Vaseline.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
07-14-2011, 01:35 PM
Moderator
Why only Vaseline? Just curious... I'm learning a lot in my RV journey
07-14-2011, 01:38 PM
Mtnguy, thanks, so this IS a common noise and I should not lose any sleep over it. Thanks for your imput!
Philadelphia PA
07-14-2011, 04:36 PM
Moderator
I am not sure, exactly. My understanding that grease will make it too slippery, negating some of the sway control.
2008 Surveyor 263
07-14-2011, 11:04 PM
If it is the chains it is normal, as the trailer turns, the WD bars move, the trailer, hitch, and bars are all fixed attachments. The variable here are the chains, the noise comes from the links of the chain slipping against each other (as they should). You could try some WD 40 on the links of the chain to allow them to slip more naturally, WD40 on the links will not affect or deter from the performance of the chains, it should quiet them somewhat.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
07-15-2011, 05:06 PM
Villa Estate 392FLFB
oil of some sorts on the chains and use will make the sounds go away.
 One state/province at a time!
07-15-2011, 05:14 PM
That noise is perfectly normal, like one poster said, if I don't hear popping in a turn, I feel something is wrong!LOL
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 612 |
| 127 members and 485 guests |
| 0721SSROO, 1l243, 4bnabird, 4kmprs, Army-dude, B47, backpacker3, bdn56, Bigmatt, bka4tcu, BlakeB, bob213, bob34787, BOBFIDY, Bobhaus, bojack, boubou, Brendan, buccello, camperman62, campfun, caper, capucine, Cards1989, Cascade Bob, CCrane2299, cgsparks1, Cowracer, crazycampers, DAISY BOYKIN, dashonthedash, dasimser, ddemme, depo, dirtman7, dumptrk, elind, f1100turbo, Falcon35, feerobk, Filthy Beast, Fire Instructor, fivecodys, FreedomTracker, fz_sledhead, GarthJ, GaryRudolph, GeneOB, GinaBruce, Gquist, gredmer, grhodes50, hark582, hokiecampers, hotrodj125, Iggy, Itsthetwoofus, J R, JAJ73, jes520, jmswms, jrlehr, jwakeman, KarenS144, kick, kixonrt66, KKapa, ktkoch, KyDan, Laura, lazyb1626, lochsa, LuckyMcBRIDE, Mad4sax, maggiek, mamentt, mark250, melbornj, Mpwelch50, mrores, mrscot, mtnguy, myredracer, Notuck, nuisance, Old car, Old Jeeper, oldiescc, onthelake, padave65, papap, pappcam, Pharmofish, pick, PrairieBoy, Ralph, rawlus, ResQMoore, RickV, RJHuser, rockin'ray, rstoro, rweier, sail2liv, scroses40, SDENN4281, sledhead77, softwarejoe, Stedman1, Taranwanderer, Timex, Titleguy, tmmar, tojo70, travyp, Triguy, trudinator, T_LMurphy, unhcharger25, venturetaz, VinceU, vlite2011, wagon52, Warrior, Waterfowlwarrior, wayward1, Westernflyer |
| Most users ever online was 996, Yesterday at 11:04 AM. |
