07-14-2011, 01:14 PM
Popping noise from chains on WD hitch
I have a Trunnion style WD Hitch, Reese PART NUMBER: 66541 with 800 lb spring bars. When ever I turn to the left or right, no matter how slight a turn, I hear a popping noise from the chains (like the chains are binding). The dealer who installed the hitch says this is normal. The noise wasn't there on the ride home after installation or the ride to my first trip. On the way home (120 mile roung trip) after I got off of the highway and making the first turn onto street, the popping noise started. I took to dealer, he observed this noise and said it was normal? Is this correct, am I damaging anything or voiding the warranty? My tounge weight of trailer trip ready is 804 pounds.
Bill
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
07-14-2011, 01:24 PM
Bill
I don't have the same equipment but I will get noise when turning if my anti-swag is too snug or tight. I don't think mine is a popping noise but more like a grinding, squealing or contact noise depending on setting and turning ratio.
If you could post a picture then the more experience members can see how you have it set up.
07-14-2011, 01:29 PM
Sorry, forgot to mention, I get this popping noise with or without the swaybar attached, I thought that was the problem but it wasn't. I read their tech tips page and I am supposed to put a drop of oil into the sockects (top and bottom), but nothing about the chains.
Bill
Philadelphia PA
07-14-2011, 01:32 PM
I have the Reese 800 lb. bars attached to the Dual Cam system. If my system didn't do the Rice Crispy sounds when I turned, I would have to back and check out if the bars are still there.
If you are using the Dual Cam system, you can quiet it somewhat by using Vaseline where the bars meet the cams. Also, grease the spring bars at the assembly head, but do not use grease on the cams.....only Vaseline.
07-14-2011, 01:35 PM
Why only Vaseline? Just curious... I'm learning a lot in my RV journey
07-14-2011, 01:38 PM
Mtnguy, thanks, so this IS a common noise and I should not lose any sleep over it. Thanks for your imput!
Philadelphia PA
07-14-2011, 04:36 PM
I am not sure, exactly. My understanding that grease will make it too slippery, negating some of the sway control.
07-14-2011, 11:04 PM
If it is the chains it is normal, as the trailer turns, the WD bars move, the trailer, hitch, and bars are all fixed attachments. The variable here are the chains, the noise comes from the links of the chain slipping against each other (as they should). You could try some WD 40 on the links of the chain to allow them to slip more naturally, WD40 on the links will not affect or deter from the performance of the chains, it should quiet them somewhat.
07-15-2011, 05:06 PM
Villa Estate 392FLFB
oil of some sorts on the chains and use will make the sounds go away.
One state/province at a time!
Full Timing - Salem Villa Estate - 392FLFB - Purchased July 29th 2010
07-15-2011, 05:14 PM
That noise is perfectly normal, like one poster said, if I don't hear popping in a turn, I feel something is wrong!LOL
Jack
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
07-15-2011, 06:36 PM
X3. My Reese Dual cam has been noisy for 3 1/2 years! I disconnect it before pulling into campgrounds, because of the excessive noises. Grease on those friction plates would make them slide off of their perch plates easily upon turning. Just normal for the Dual cam setup, unfortunately. Randy
07-15-2011, 08:44 PM
What does a dual cam WD look like? I mean, I know what it is, just want others to know, in case they don't.
Philadelphia PA
07-16-2011, 05:53 AM
Originally Posted by bilcin
what does a dual cam wd look like? I mean, i know what it is, just want others to know, in case they don't.:d
Looking at that picture, it is not set up very well. Looks like the dual cam in not centered in the spirng bar notch.
07-16-2011, 10:25 AM
Mine looks different than that pic, but mine may be an older setup. Close though. Randy
