Old 10-16-2016, 03:28 AM   #21
Never lubricate a friction sway control bar. It would defeat its purpose.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 10-16-2016, 09:20 AM   #22
Popping noise when turning
I had that problem when I had a TT, it turned out to be the anti sway bar was too tight. Just a thought.
johnshoe is offline   Reply With Quote
Old 10-16-2016, 09:45 AM   #23
Read your pamphlet and find out if there is something recommended that you aren't doing.
JoJackKerr is offline   Reply With Quote
Old 10-16-2016, 10:16 AM   #24
Crookedread
crookedread's Avatar
I think Johnshoe may have the answer. I have that same popping noise but only when my anti sway bar is tight. Recently when crossing Wyoming, it was really windy so I cranked the anti sway bar pretty tight. Normally when I come into a town or will be looking around, I loosen the anti sway bar until it is loose. Forgot this time and while jockeying out of a grocery store parking lot got that crunching pop from the hitch. So yes, that is fairly normal but you can mitigate the problem by loosening the bar as soon as possible and running as loose as comfortable. By the way, I use Reese brand lubricant on the ball. Welcome to the club!!
Crookedread
2016 2500 Duramax
2011 Stealth 2312
crookedread is offline   Reply With Quote
Old 10-16-2016, 10:21 AM   #25
Hearing those creaks and pops on tighter turns lets me know the Equal-i-zer is back there and working.
keith_h is offline   Reply With Quote
Old 10-16-2016, 11:34 AM   #26
john5646's Avatar
I use this grease from nappa. See picture. Everyone has what works for them, I wipe it off when not in use. I hate dirty hands, so it's a few minutes I don't mind.
Most important do not grease L brackets. At most use plastic jackets sold by equalizer. I use the jackets more often than not. It I'm heavy highway I choose not to use them, too gain the mild added sway control, some is lost with there use. In theory they allow less friction so therefore less sway control. Do I notice a difference with and without. Not that I can tell.... so that's why I choose to use when situation is such that I may want all I can have. Click image for larger version
Name:	ImageUploadedByForest River Forums1476635627.545393.jpg
ID:	123123Click image for larger version
Name:	ImageUploadedByForest River Forums1476635638.849188.jpg
john5646 is offline   Reply With Quote
Old 10-16-2016, 08:05 PM   #27
Thank you all so much! Had a great trip and didn't freak out on the way home thanks to you all. No more duplicate posts for me, sorry, I was a bit anxious!
Bliss9273 is offline   Reply With Quote
Old 10-17-2016, 08:41 AM   #28
djemgoss's Avatar
WDH noise
I have a Equal-i-zer WDH. I keep it lubed up and my dealer also recommended using their "Sway Bracket Jacket" P/N 95-01-5150. Its made from a high density nylon and just slips on the "L" brackets. It was designed to quiet your Equal-i-zer hitch and reduce wear on the L-brackets.
https://www.rvupgradestore.com/Equal...-p/94-6399.htm
ID:	123218   Click image for larger version
ID:	123219   Click image for larger version
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 10-17-2016, 10:44 AM   #29
MilCop4523's Avatar
2017 Greywolf Toy hauler with our original 2011 Reese dual cam sway control system snaps like a trooper when making turns.
they all do. It's to let you know its there.
gets worse on sharp turns I bet.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
noise
