Old 10-14-2016, 04:33 PM   #1
Popping noises while turning--normal???
So, the trailer is making noises when we make turns. Is that normal or are is our trailer gonna fall off?!
Bliss9273 is offline   Reply With Quote
Old 10-14-2016, 04:46 PM   #2
Popping noises when turning normal or disastrous??
Obvious newbs but when we turn we hear what I can only describe as some kind of popping or loud rubbing noise coming from the trailer/hitch. Is that abnormal?
Old 10-14-2016, 04:46 PM   #3
What kind of trailer? 5th wheel, Bumper pull?? If BP, are you using a WDH?
guyster is offline   Reply With Quote
Old 10-14-2016, 04:49 PM   #4
Travel trailer, is that a bumper puller? Yes to the WDH.
Old 10-14-2016, 04:50 PM   #5
Sorry! Travel trailer with a WDH.
Old 10-14-2016, 04:50 PM   #6
Turning noise?
Check other threads here and you more than likely don't have a Blue Ox equalizer hitch. Present trailer is our third rig and my first Blue Ox WD hitch which seems a bit softer than the previous sway bar equalizer hitches I've used.
That should not be a problem unless you see something broken or loose on the frame.
Charles & Martha Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2016 Flagstaff V-Lite 30WFKSS
Almost South of the Border
whatsupchuck is offline   Reply With Quote
Old 10-14-2016, 04:54 PM   #7
Originally Posted by Iggy View Post
It would be great if you told us what you have that is making the noise.
Trailer, 5th wheel Class A or Class C.
Thank you
"...loud rubbing noise coming from the trailer/hitch."
Old 10-14-2016, 04:55 PM   #8
WDH does make noise when turning. Not all but most do.
Old 10-14-2016, 05:04 PM   #9
crunchman12001's Avatar
Can you provide the year, make and model of your travel trailer? Also, what type, brand of WDH do you tow with? Are you also using an add on friction sway bar?
I will assume you hear there popping sounds while turning and going slow?
2015 F-250 FX4
Old 10-14-2016, 05:06 PM   #10
Croaker's Avatar
Grease the ball and if you have an EQUILIZER four way Weight Distribution Hitch (WDH) they make a pad to reduce noise. I also grease the WD bars on the sides.
These hitches also need grease where the WD bar hinges/moves. (In the owners manual) and correct torque
Croaker is offline   Reply With Quote
noise
