10-14-2016, 04:33 PM
Popping noises while turning--normal???
So, the trailer is making noises when we make turns. Is that normal or are is our trailer gonna fall off?!
10-14-2016, 04:46 PM
Popping noises when turning normal or disastrous??
Obvious newbs but when we turn we hear what I can only describe as some kind of popping or loud rubbing noise coming from the trailer/hitch. Is that abnormal?
What kind of trailer? 5th wheel, Bumper pull?? If BP, are you using a WDH?
10-14-2016, 04:49 PM
Travel trailer, is that a bumper puller? Yes to the WDH.
10-14-2016, 04:50 PM
Sorry! Travel trailer with a WDH.
Turning noise?
Check other threads here and you more than likely don't have a Blue Ox equalizer hitch. Present trailer is our third rig and my first Blue Ox WD hitch which seems a bit softer than the previous sway bar equalizer hitches I've used.
That should not be a problem unless you see something broken or loose on the frame.
Charles Myatt
2009 Duramax w/Transfer Flow Fuel Tank
2017 Rockwood Windjammer 3029
Almost South of the Border
10-14-2016, 04:54 PM
Mod free 5er
Originally Posted by Iggy
It would be great if you told us what you have that is making the noise.
Trailer, 5th wheel Class A or Class C.
Thank you
"...loud rubbing noise coming from the trailer/hitch."
10-14-2016, 04:55 PM
WDH does make noise when turning. Not all but most do.
10-14-2016, 05:04 PM
Can you provide the year, make and model of your travel trailer? Also, what type, brand of WDH do you tow with? Are you also using an add on friction sway bar?
I will assume you hear there popping sounds while turning and going slow?
2015 F-250 FX4
10-14-2016, 05:06 PM
Grease the ball and if you have an EQUILIZER four way Weight Distribution Hitch (WDH) they make a pad to reduce noise. I also grease the WD bars on the sides.
These hitches also need grease where the WD bar hinges/moves. (In the owners manual) and correct torque
10-14-2016, 05:18 PM
2017 26DBH. 500$ hitch with sway bars. Neither of us know the brand . Yes, it's when we are going slow and turning.
Thanks for the tip about greasing!
10-14-2016, 05:19 PM
Thanks, we just wanted to make sure it was a normal trailer noise!
10-14-2016, 05:23 PM
Looks like you have 2 threads going. Yes, it is normal.
Happy camping
2015 F-250 FX4
10-14-2016, 06:26 PM
Happy camping
Yep, two threads now merged into the Towing, Tow Vehicles, Hitches & Toads forum .
10-14-2016, 06:51 PM
Yes...normal
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
3 nights camped so far in 2020
10-14-2016, 07:14 PM
Pictures say a thousand words. Include one and someone will be able to identify....maybe.
Chip Bruce, RPh
Kansas City, MO
10-15-2016, 12:50 PM
Axle grease on the ball and also the pivot points on your weight distribution bars. This is where I found most of my noise coming from. I have a Reese straight line hitch. Now the only noise I get is a pop sometimes when the trunnion bars return to the cam saddles.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
10-15-2016, 01:52 PM
We have been using white grease, rather than the dark color. Much easier to clean up and works good for us.
2014 35 V-Lite 30WIKSS Platinum
Expedition 5.4, Hankook, Reese 1200 Round Bar, Trans-Go, Hadden, Curt Tri-Flex, 3.73 Posi-Traction
10-15-2016, 06:14 PM
popping noise.
Do you have a friction type sway control? If yes, it is normal.
10-15-2016, 07:06 PM
We carry a grease gun. The weight distribution hitch requires it often. We had terrible sounds until we learned that.
