Old 06-09-2015, 11:34 AM   #1
Cyoul8r's Avatar
Portable Jump Starter
I'm wanting to get a portable jump starter to take along in case of an emergency. I have a 2012 F250 6.7 diesel and wonder how much power (amps) I would need to crank it. It currently has two 750 CCA batteries. I don't need the frills that come along with some of them, just starting power. Anyone have this diesel and a jump starter that is compatible?
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline   Reply With Quote
Old 06-09-2015, 12:15 PM   #2
Fulltime family RVer
No idea about anything you asked.
I can only say that during my debacle in Ohio, when I let my batteries die badly- it took a good 10 minutes of being hooked up to my neighbors truck to get the battery recharged to the point that I could start up.
ependydad is online now   Reply With Quote
Old 06-09-2015, 04:42 PM   #3
f5moab's Avatar
I have one of these, and can say from experience, I have started a H1 diesel (dual battery system) a few times; and one day, for over an hour, cranked the engine numerous times to troubleshoot a fuel problem. I have also used it when working on my popup when I adjusted the limits switches for the power winch. Lifted and lowered the roof at least a half dozen time. (Too lazy to pull the batteries out of the garage an connect.)
Only frill is the charge port (accessory plug) can be used to power a small Cobra converter if needed.
You can charge it via the accessory plug from a running vehicle. I comes with a cord with two male plugs; this is a time charge and you must disconnect manually to keep from overcharging the battery. Or you can just plug a female end of an extension cord into the charge port; this is automatic and can be left plugged in at all times since it will cut charging automatically.
Amazon.com: Jump-N-Carry JNC660 1700 Peak Amp 12-Volt Jump Starter: Automotive
f5moab is offline   Reply With Quote
Old 06-09-2015, 04:45 PM   #4
Portable Car Battery Jump Starters | Batteries, Battery Chargers + Battery Jump Starters | Automotive | Northern Tool + Equipment
lower page
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 06-09-2015, 06:21 PM   #5
Just bought a Stanley FatMax 700 yesterday @ Walmart. Also has a compressor that goes up to 120 psi. Haven't used it yet, so I hope it will do.
Papa GLS is offline   Reply With Quote
Old 06-11-2015, 11:57 AM   #6
Cyoul8r's Avatar
Has anyone tried this?
Robot Check
Old 06-11-2015, 12:09 PM   #7
B47
Robot Check
No. But the majority of reviews like it. A couple of reviews said Amazon doesn't accept returns. I have returned a few items (not electrical) with no problems.
B47 is online now   Reply With Quote
