Old 05-18-2014, 03:14 PM   #21
Iggy's Avatar
2012 Georgetown XL - 378TS 49,000 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 115 days)
USAF Retired - MSgt
Old 05-20-2014, 08:46 AM   #22
Plain Old Member
Looks fine. Usually though the bars should be close to parallel with the frame in best case scenario. Use the adjustment washers to tilt the head back and you'll have to adjust which chain link you're on. Same effect, less likely to tag the frame on certain terrain.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-20-2014, 11:24 AM   #23
ironj's Avatar
Originally Posted by kenfowler View Post
obviously the road isn't perfectly flat....but the tongue was level according to the level
the only way to KNOW is to hit some scales and weigh the axles with/without trailer wdh .....YES the bars should be parallel to the trailer frame, and YES you want the trailer as level as possible as to keep axle weights equal... having the bars set to eliminate the sag may be to much or just right.....all depends on how you lifted the truck...
mine was lifted with blocks in the rear so original spring rate was exactly as stock....even then i bagged it because the HID's were blinding everyone for 4 miles with the slight stock sag (even with hitch adjusted perfect)..ive had issues with lifted spring packs before....especially progressive packs for lifted applications.....the soft top portion lends to a lot of sag when towing....
also, i HATE towing with the nittos on mine....even at 65psi the sidewall flex/sway is annoying and there is a 2-3 mpg difference between the nittos and my stock michellin 20"s at 75psi while towing .
other than that, it looks like you have a pretty decent starting point.....its always a fine tuning process with wdh...and how you load can make a try and set bars at LOADED tongue weight....
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 05-20-2014, 11:33 AM   #24
Flagstaffer06's Avatar
X2 on the comments about loading. I have a pretty much stock Nissan Titan, tows our trailer very well. It took me a trip or two and some towing around to get the setup right on my WDH. One huge difference was the propane tanks being full vs empty. Obviously it adds weight but, those coupled with how the front compartment is loaded or things stored on the bed in the front of ours makes a good difference.
Good luck!
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 05-27-2014, 11:16 AM   #25
thebrakeman's Avatar
There are no dumb questions.
However, there are dumb thread titles.....
thebrakeman is offline   Reply With Quote
