04-15-2016, 09:03 PM
#2581
Originally Posted by jpforsyth
I bought an adapter and welded it to the 2 inch shank. That took out the slop between the shank and the adapter. Also keeps the holes lined up.
That idea crossed my mind and may be a viable option. Hopefully tomorrow I can see if the drop is going to be low enough.
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
04-15-2016, 09:07 PM
#2582
Originally Posted by wicked1
On my F350 I have the multiple adapters from the factory in the receiver and longer pin. I have the Anderson WDH but I think I will be ok going to the bottom holes in the 4" shank but only rough guessed with a tape measure this week I am going to redo the whole thing and see where I am at.
One thing I did realize as you did, add on parts like if I had to get a new shank for mine is $159.00, I have my old Camco EZ-Lift but I am not going back to bars and Sway Bar type control.... Next week will tell all, going to a fifth wheel at end of 2017 season but I need to come up with a solution for this year and 2017.
Good Luck
Same boat here. Don't want to invest too much as we will probably end up in a 5'er in early 2018. Just thought, I need to check under all of the back seat and make sure there are not any adaptors or hitch pins laying around.
04-15-2016, 09:19 PM
#2583
Originally Posted by fireman1317
Wicked, I went to redo my WDH tonight and learned a couple things that you may run into as well. My original shank is 2". New truck has a 2 1/2" receiver. Bought reducer sleeve from Tractor Supply, but it's a big pain in the a$# to get all the holes lined up. Also, I need a longer hitch pin. Also, I flipped my shank and lowered the ball as far down as it will go and I'm pretty sure I still don't have enough drop.
Looked in my RV Wholesalers catalogue and saw they carry an Equalizer 2 1/2" shank with I think a 12" drop. Only $200 Any one else run into this situation? Is buying a new shank the best way to go?
I don't know if ford is the same as GM, but I had a Reese adapter when I picked up my truck, and it was hard to line up and lose as can be. Bought an OEM adapter and it has a lip that allows it to only slide back so far in the hitch to where the holes line up and fits tighter. I'd actually ordered a new shank from Etrailer but cancelled the order after getting the OEM adapter.
Sean
'16 28DBUD
'16 2500HD Dmax
04-16-2016, 02:34 AM
#2584
2007 WildCat 32QBBS
You can find the class V adapter @ Walmart too. It was around $12.
04-16-2016, 05:06 AM
#2585
I had the same problem... when I upgraded to a 3/4 ton a number of years ago I had to get an 8" drop shank. This winter I upgraded TV'S to the dually which has the 2 1/2" hitch... I really don't like the adapter sleeve, it's too sloppy. If I weren't picking up my new 5er today, I would get a new shank in 2.5".
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
04-17-2016, 06:04 AM
#2586
Our first trailer was a Trailmanor 3023. Our newest trailer is a Surveyor Select 291.
04-17-2016, 06:40 AM
#2587
Getting prep'ed for our trip to Cape Hatteras KOA.
04-17-2016, 10:10 AM
#2588
Why one white wheel and one aluminum?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
04-17-2016, 11:14 AM
#2589
It was a private sale. When I went to pick it up it had a flat tire, so we had to change it with the spare.
04-17-2016, 11:45 AM
#2590
Picking up at storage:
Loaded up for camping:
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
04-17-2016, 05:11 PM
#2591
Headed that way next month. Let me know how it is and what's to do down there.
04-17-2016, 07:50 PM
#2592
Camping yesterday.
2016 Hyper Lite XLR 30HDS
2015 GMC Sierra Denali 3500, Duramax,CC,LB,DRW, 3:73
2016 Ram Laramie 3500, Cummins,CC,LB DRW, 4:10
04-22-2016, 08:11 AM
#2593
White 2016 Work & Play Ultra 25ULA, Cherry Wood, Pebble, Onboard Onan 5.5, Onboard Fuel Station, 50-Amp Service Onyx Black 2015 Chevrolet Silverado 2500HD DCSB, 6.6 Duramax/Allison, LTZ/Z71 397bhp/765t Black Raven 2015 Cadillac Escalade Premium 420 bhp/460t Merlot Sunglo 2011 Harley Davidson Street Glide FLHX, FM 107", PM Heathens 21"/17", Metzeler ME880's (200 Rear), CVO Rear, Chain Drive 116rwhp/127rwt
04-22-2016, 05:28 PM
#2594
Here is ours
Live, Laugh, Love to Camp
2018 Sandpiper 38 FKOK
2012 Ram 2500HD Crew Cab 4WD 6.7 Cummins 3.73
18k Pullrite Autoslider
2014 Harley Davidson FLHTK
Day Camped: 2015 - 45 2016 - 4
04-22-2016, 07:08 PM
#2595
Looking for opinions on helper springs VS air bags. My truck is a 2006 Ram 2500 cummins. My truck is mainly to pull our 35' 5er. Any suggestions?
04-22-2016, 07:11 PM
#2596
Done with this
Bags are fully adjustable. Springs are helping all the time, regardless.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
04-22-2016, 07:14 PM
#2597
I go for air bags, doesn't affect the ride when not inflated. Most helper springs give a harsher ride when truck is unloaded.
04-22-2016, 07:18 PM
#2598
04-22-2016, 07:56 PM
#2599
I was under the impression that they only take affect when there is a heavy load on them. I'm already in a 3/4ton so it's already real stiff.
04-22-2016, 08:12 PM
#2600
Packed and ready in front of the house before leaving to snowbird in FL
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
