07-01-2017, 02:32 PM
#3521
Originally Posted by GirlsCamp2
Thank you for the suggestion, I would like to try a WDH and see if I notice much of a difference.
Pulled ONE single axle TT ~~ a brand new 1979 model. One trip w/o sway control and that proved a mistake. The difference WD and sway control is huge. Just thinking of a flat at 60 mph with a single axle convinced me to get a double axle TT.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
07-01-2017, 04:16 PM
#3522
So Far. so good. Surprisingly, only a slight decrease in gas mileage. Most of the time, hardly notice it's there.
Calgary, Alberta
2017 Cherokee 274DBH(It's dead Jim!)
2021 Rockwood UltraLite 2608BS
2008 Chev Silverado LTZ 6l
07-01-2017, 10:25 PM
#3523
I always use a sway bar, it's on the other side. That suckers saved my bacon coming across I80 through Wyoming in a wind storm.
07-01-2017, 10:31 PM
#3524
Post up your towing pics!
Love my Wolf Pup, although I'm not sure about how I feel about how level it is with my current hitch.
I don't know the weights of your trailer, but
check the weight ratings on that stinger. Likely good for only 500lbs of tongue weight.
If that's enough, you can try to flip the stinger and ball over to raise the nose and see if it sits level.
This might change the towing characteristics as it is quite nose down atm.
#3525
Originally Posted by 007matman
I used to use a WDH on my Pop-up. It'll make a huge difference.
Also, I've always been fanatical about getting the trailer level due to someone telling me that you'll getting longer life out of the fridge and the back end of the vehicle if it's as close to level as possible.
That's the exact reason why I like being level. My old camper's fridge wouldn't work unless it was level. (While parked, I didn't have it on when towing)
07-01-2017, 10:49 PM
#3526
Thanks for the advice. My weight limit on it is 7500 (just double checked) and the rig loaded is just under 4000. The hitch is dropped two inches, which I think is the problem? I'm looking into either a new hitch, same set up with a sway bar, or the WDH. Truck can easily handle the weight and load and I love that I can hitch up in under two minutes with the current set up so that is my big concern with the WDH.
07-01-2017, 11:33 PM
#3527
New TV - traded the 2500 for a 3500.
The 2500 was great till the road got rough. Coil springs just couldn't hack it.
Thought about air bags but I'd have still been over weight.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
07-02-2017, 12:00 AM
#3528
Measure from the road to the bottom edge of the frame near the axle and at the front near the hitch. The difference will be close the how far you need to come up at the hitch. If it's around 4", you can get that just by flipping the hitch upside down and remount the ball. Less or more than 4" you'll want to get a new hitch.
07-02-2017, 12:10 AM
#3529
Right there, most helpful response! 1.75 inches lower on the truck. Guess I'm getting a new hitch! Thank you!
07-02-2017, 06:42 AM
#3530
i have an E2 WDH it takes me about 5 minutes to hookup
2017 Micro Lite 21FBRS (sold)
2019 GMC Sierra 2500 HD extra cab Z71
looking for the perfect 5er over the winter
07-02-2017, 07:42 AM
#3531
Wolfpup owner
I have a Wolfpup and the WDH makes a huge difference. Can't hardly tell it's back there
07-03-2017, 04:23 AM
#3532
Thought about air bags but I'd have still been over weight. Attachment 143337
Yeah 3500 for sure, nice setup.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
07-03-2017, 09:20 AM
#3533
I think you mean 1/2 of the difference.
UPDATE: Nevermind. Thought you'd said at the rear, not the axle!
Although measuring at the rear can be easier than at the axles sometimes.
2011 Traverse LT, 3.6L, FWD
07-04-2017, 06:21 AM
#3534
Traded in my FR Greywolf 22RR last weekend.
8 months of ownership was brutal.
Finally after 76 emails back and forth between 6 different level FR sales and management we said its not worth the hassle to continue my consumer relationship with them.
3 days - 4 States, 3 Provinces and we made it home.
Switched from this to this...
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
07-04-2017, 07:47 AM
#3535
Coachman 312BHDS
When are you getting your new truck to pull that thing?
2017 Open Range Roamer RF376FBH 42' fifth wheel
2016 F-350 Lariat SCrew 6.7L Turbo Diesel SRW - Extang Fold-up Hard tonneau cover - Husky 16k Fifth Wheel Hitch
07-04-2017, 11:35 AM
#3536
07-04-2017, 11:36 AM
#3537
Indiana Beach. Family Reunion.
07-04-2017, 12:49 PM
#3538
Return trip from the Grand Canyon. Quick bite at Gas Monkey bar and grill.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
07-04-2017, 01:52 PM
#3539
Lol its a Ford not a Dodge
My max tow is a Lot more than the 8420 lbs the trailer is dry weight.
07-04-2017, 02:54 PM
#3540
Nice. What ford did you get
