Old 04-15-2016, 10:03 PM   #2581
fireman1317's Avatar
Originally Posted by jpforsyth View Post
I bought an adapter and welded it to the 2 inch shank. That took out the slop between the shank and the adapter. Also keeps the holes lined up.
That idea crossed my mind and may be a viable option. Hopefully tomorrow I can see if the drop is going to be low enough.
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 04-15-2016, 10:07 PM   #2582
Originally Posted by wicked1 View Post
On my F350 I have the multiple adapters from the factory in the receiver and longer pin. I have the Anderson WDH but I think I will be ok going to the bottom holes in the 4" shank but only rough guessed with a tape measure this week I am going to redo the whole thing and see where I am at.
One thing I did realize as you did, add on parts like if I had to get a new shank for mine is $159.00, I have my old Camco EZ-Lift but I am not going back to bars and Sway Bar type control.... Next week will tell all, going to a fifth wheel at end of 2017 season but I need to come up with a solution for this year and 2017.
Good Luck
Same boat here. Don't want to invest too much as we will probably end up in a 5'er in early 2018. Just thought, I need to check under all of the back seat and make sure there are not any adaptors or hitch pins laying around.
Old 04-15-2016, 10:19 PM   #2583
Phenom's Avatar
Originally Posted by fireman1317 View Post
Wicked, I went to redo my WDH tonight and learned a couple things that you may run into as well. My original shank is 2". New truck has a 2 1/2" receiver. Bought reducer sleeve from Tractor Supply, but it's a big pain in the a$# to get all the holes lined up. Also, I need a longer hitch pin. Also, I flipped my shank and lowered the ball as far down as it will go and I'm pretty sure I still don't have enough drop.
Looked in my RV Wholesalers catalogue and saw they carry an Equalizer 2 1/2" shank with I think a 12" drop. Only $200 Any one else run into this situation? Is buying a new shank the best way to go?
I don't know if ford is the same as GM, but I had a Reese adapter when I picked up my truck, and it was hard to line up and lose as can be. Bought an OEM adapter and it has a lip that allows it to only slide back so far in the hitch to where the holes line up and fits tighter. I'd actually ordered a new shank from Etrailer but cancelled the order after getting the OEM adapter.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 04-16-2016, 03:34 AM   #2584
2007 WildCat 32QBBS
05CrewDually's Avatar
You can find the class V adapter @ Walmart too. It was around $12.
05CrewDually is offline   Reply With Quote
Old 04-16-2016, 06:06 AM   #2585
shorthorn's Avatar
I had the same problem... when I upgraded to a 3/4 ton a number of years ago I had to get an 8" drop shank. This winter I upgraded TV'S to the dually which has the 2 1/2" hitch... I really don't like the adapter sleeve, it's too sloppy. If I weren't picking up my new 5er today, I would get a new shank in 2.5".
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is online now   Reply With Quote
Old 04-17-2016, 07:04 AM   #2586
Our first trailer was a Trailmanor 3023. Our newest trailer is a Surveyor Select 291.
ID:	105167   Click image for larger version
Alvega007 is offline   Reply With Quote
Old 04-17-2016, 07:40 AM   #2587
Getting prep'ed for our trip to Cape Hatteras KOA.
Martsing is offline   Reply With Quote
Old 04-17-2016, 11:10 AM   #2588
wicked1's Avatar
Why one white wheel and one aluminum?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-17-2016, 12:14 PM   #2589
It was a private sale. When I went to pick it up it had a flat tire, so we had to change it with the spare.
Old 04-17-2016, 12:45 PM   #2590
m2kamp's Avatar
Picking up at storage:
Loaded up for camping:
2015 Wildwood 26TBSS GVWR 7815lbs/Equalizer 4pt 10k
2016 Ram 2500 CC Tradesman 6.4L 4x4 3.73 GVWR 10000lbs, 3176lb Payload, 12630lb Tow, Max Tongue 1800, GCWR 19800
2017 Ram 1500 CC Lone Star 3.6L 4x2 3.55 GVWR 6800lbs, 1673lb Payload, 7510lb Tow, Max Tongue 1100, GCWR 12900
m2kamp is offline   Reply With Quote
