02-02-2016, 07:14 PM
#61
2012 Ford F-150 Ecoboost 6.5' bed
GVWR 7700 lbs.
FGAWR 3900 lbs.
RGAWR 4050 lbs.
Combined cargo 1658 lbs.
2016 Rockwood MiniLite 2503S
Base dry weight 4310 lbs
Base dry hitch weight 538 lbs
Cargo capacity 1833 lbs
2020 Rockwood 2608BS
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
2021 Ford F-250 Super Duty
02-02-2016, 07:18 PM
#62
GVWR 7700 lbs.
FGAWR 3900 lbs.
RGAWR 4050 lbs.
What is combined cargo?
Bruce
02-02-2016, 07:31 PM
#63
Combined cargo is 1658 lbs
02-02-2016, 07:33 PM
#64
I think that combined cargo means passengers and cargo combined.
02-02-2016, 07:45 PM
#65
1/2 ton specs
Have to represent the GM guys...
2015 GMC Sierra Double Cab...Max Trailer Package
- 6.2 liter
- 8 speed tranny
As per door
- Payload - 2035
- GVWR - 7600
- GAWR FT - 3950
- GAWR RR - 4300
From manual
- Axle ratio - 3.42
- Max trailer - 11,900
- GCWR - 17,700
2016 PT Crusader 294RLT - 33'11" - 5'er
- Unloaded - 9000
- PW - 1290
- Loaded ?? Just picked it up Friday
02-04-2016, 05:41 PM
#66
Originally Posted by f5moab
I'm confused. My 2015 Silverado 1500 LTZ CC 4WD owner manual states:
1500 Weight-Carrying 363 kg ( 800 lb)
1500 Weight-Distributing 544 kg ( 1,200 lb)
And that matches the sticker on the hitch, and that matches what GM engineering told me in regard to a 2013 Silverado, when I contacted them due to a different spec on the hitch vs. the owner's manual.
SPECS: - 5.3L V8
- 6-Spd Trans
- 4-Door Crew Cab
- Overall length: 230.03
- Wheelbase: 143.5
- Axle: 3.42
- GCWR: 15000 lbs.
- GAWR for front and rear axles: 3900 lbs.
- max. towing weight rating: 9200 lbs
- max. payload rating: 1662 lbs
Oh, don't worry, there's quite allot to confuse people. The 500 lbs thing isn't in any literature that comes with your truck, and it isn't stamped or stickered either. Then again, I don't think that a GCWR is anywhere either.
If you don't like my opinion, I'll give you a full refund on what you paid me for it.
02-22-2016, 11:05 PM
#67
I previously posted a few weeks ago. However, I upgraded last week from a 4.6L without a tow package to a 5.7L with a full tow package.
2016 Tundra SR5 XSP-X, Double Cab, Standard Bed
Full Tow Package
38 gal fuel tank
5.7L V8
381 HP
401 lb-ft torque
4.30 rear diff.
Curb Wt 5185
GVWR 6900
Payload 1715
Max Tow 10,300
2016 23LB Micro Lite
Max Gross Wt 4,830
02-23-2016, 10:15 AM
#68
2011 Ram 1500 Crew 4x4 Longhorn
5.7L Hemi, 3.55 gears, 5 speed Auto
GVWR - 6800
Payload - 1340
Base Weight:
Total - 5431
Front - 3008
Rear - 2423
GAWR:
Front - 3900
Rear - 3900
GCWR - 14000
Max Trailer - 8350
Don't have our trailer yet. We are looking for a lightweight Toy Hauler to haul my 550 lb motorcycle. I'd like a Wolf Pup but she wants something a tad bigger. This forum is helping a LOT with my research.
1953 Ford NAA Jubilee
2015 Kawasaki Versys 1000 LT
2016 Ram 2500 Cummins, Crew, Longbed, 4x4
02-23-2016, 10:26 AM
#69
Full Tow Package
38 gal fuel tank
5.7L V8
381 HP
401 lb-ft torque
4.30 rear diff.
Curb Wt 5185
GVWR 6900
Payload 1715
Max Tow 10,300
Max Gross Wt 4,830
I'm glad to see they upped the fuel capacity and payload!
02-24-2016, 02:14 PM
#70
2014 F150 EB SCREW 6.5' bed 3.73 gears
Max Tow Package
36 gal. tank
Front: 3900lb
Rear: 4050lb
Payload: 1766
GVWR: 7700
Pulling a 2014 Roo 233s. Dry is around 4300, gross is around 6400.
2022 F250
2014 Rockwood Roo 233s
03-05-2016, 06:55 AM
#71
2015 Ram 1500 Crew Cab 4x2 Lone Star (Big Horn) Hemi 8 spd Auto 3.21 Rear End 140.5" Wheelbase
GVWR 6900
GCWR 13900
GAWR (Front) 3600
GAWR (Rear) 3900
Mfg listed tow rating: 8170
Payload (Yellow Door Sticker) 1490
I added Monroe Load Adjusting Shocks before I bought the camper. With loaded tongue and no WD, my camper levels my truck (see sig) (850+ tongue weight). Great $80 upgrade. No porpoising and tows great with my e2 hitch. I am thinking about adding Tuftruck HD springs TT-1211 designed for towing and going to LT 17" tires. POS OEM Goodyear P-Tires aren't great for towing.
We load as much as possible into the camper and with my family of 4 aboard I am 100lbs under GVWR per CAT scales. Camper came in at 6000 ready to camp. I need to go back to the scales to weigh with camper unhitched as I think my tongue weight is high (Yellow sticker UVW on the camper is 5919)
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
03-05-2016, 07:54 AM
#72
I'm towing a rockwood 8285 ikws 5er with a Z71 half ton 4 wheel drive with a 6.2 Liter engine and airbags. I have no problems and is very stable. Also getting 12.3 miles to the gallon on the average. Pretty good for everybody I've talked to that a half ton shouldn't do it. Oh and on the scale camper loaded is appox. 8500 lbs. with pin weight of 1400. So the thing is pick the right 5er for your trucks cap. and stick to it. Happy trails!!!
03-05-2016, 08:21 AM
#73
Only worried about the '13 when I first got it, that is why I contacted GM engineering. The 2015 I purchased two years later had the same spec on the hitch and in the manual; 800 lbs.
BUT, if you read the manual, there can be some confusions about this statement about 500 lbs max:
"If a cargo carrier is used in the
trailer hitch receiver, choose a
carrier that positions the load as
close to the vehicle as possible.
Make sure the total weight,
including the carrier, is no more than
half of the maximum allowable
tongue weight for the vehicle or
227 kg (500 lb), whichever is less."
But that is only for a hitch carrier that causes some unique torque to the hitch that you will not get with a trailer hitch with a ball.
02-12-2017, 01:09 PM
#74
Originally Posted by Wobbles
I think I am safe. What say you? These are my specs, without having been scaled yet.
2014 Ford F150 XLT Supercab 4x4 5.0,145-in WB, 3.55 Gears
5461 Base Curb Weight
7350 GVWR
7800 Max Loaded Trailer Weight
13500 GCWR
1830 Payload Capacity
2015 Cherokee Grey Wolf 26BH
402 Dry Hitch Weight
4579 UVW
2823 CCC
7402 GVWR
Note:
I have asked on the forum here about tongue weight and the reply's with two bottles and battery plus an estimate of cargo in the TT between 1k and 1.5k of junk, I will have a hard time getting near the 15%.
I cannot think that I would ever get near the 1.5k of cargo unless I let the DW use the TT as a place where stuff goes to die.
How does your rig tow in the mountains? We've just placed a deposit on a 2017 26DBH.
DRY HITCH WEIGHG 765 lbs
UNLOADED VEH WEIGHT 6300 lbs
GVWR 7765 lbs.
TV:
2013, F-150 XLT 4x4. 5.0 with 3.55. 145" WB. Wondering if we bought bigger than we can handle [emoji31]
2013 Ford F-150 5.0 Super Crew 4x4
2017 Grey Wolf 26DBH
03-03-2017, 10:19 AM
#75
Beauty and the Beast
Primary Tow Vehicle:
2006 Dodge Ram 2500 Mega Cab Laramie, 4X4, 5.9l Cummins, 48RE auto trans in White.
All weight ratings and towing capacities far exceed what we need.
Secondary Tow Vehicle:
2017 GMC 1500 SLT, 6.2l, 8 speed automatic trans, 3.23 gears, crew-cab, short bed in Pepperdust Metallic.
GVWR: 7200
GAWRF: 3950
GAWRR: 3950
Payload: 1505
Max Trailer: 9100
GCVWR: 15000
These are now followed faithfully by a 2017 Rockwood Roo 23IKSS. They used to drag a 2005 Jayco 1206 pop-up.
