01-29-2016, 07:26 AM
Canadian Member
Post Your 1/2 Ton's Specs
There are a lot of threads here on the FRF about towing large TTs and 5ers with a 1/2 ton TV but the actual specs and capabilities of 1/2 tons can vary greatly. So I thought I would start a thread for members towing with a 1/2 ton to post up their TV's factory specs to see how much they vary and what members are towing using those specs.
This tread is not intended to start a debate about whether anyone is within specs or crazily overloaded....Just to see the variety of 1/2 ton specs out there.
I'll start.
2009 Ford F-150 XLT crew cab, 5.4L, 5.5' box
Max. towing package rated for towing 11200#
No HD payload package
GVWR 7200#
RGAWR 4000#
FGAWR 3850#
Payload 1560# (according to the 2009 Ford spec sheet)
CCC 1360# (according to the yellow sticker in the drivers door)
I've modded the truck by adding and extra leaf spring on each side and LT tires.
Towing the 32' TT in my signature. I haven't had it to a set of scales yet but the sticker UVW is just shy of 6200# so I should be at around 7100# loaded.
01-29-2016, 11:35 AM
2014 Ram 1500 4x4 Outdoorsman with a 5.7L Hemi, 8 Speed Trans, 3.92 Rear end and 5'7" box
GVWR 5,365#
Payload 1530#
Max Tow Rating of 10,150#
GCWR 15,950#
I added Airlift 1000 airbags to help with the saggy Ram suspension.
I tow a Grey Wolf 26DBH with a:
Dry Tongue Weight 725#
Dry Weight 5,795#
GVWR of 7,725#
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
01-29-2016, 11:37 AM
Originally Posted by JustB_Rad
2
RGAWR 2,260#
FGAWR 3,106#
Huh? Typos? Can't be right. 2260 seems awful low for a truck?
01-29-2016, 11:52 AM
That's whats listed on the chart directly from Ram as the Base Weight.....GAWR for Front and Rear are both 3,900# Not sure exactly how they have it listed....rather confusing.
01-29-2016, 12:00 PM
Not sure what chart you are looking at but this one says front and rear GAWR are 3900 and GVWR is 6900. https://www.ramtrucks.com/assets/tow...ing_charts.pdf
Me 2013 RAM big horn 4X4 5.7 3.55 Quad cab
truck specs
as above
CCC a massive 1100 lbs
Max tow 8400 lbs
trailer
2012 Vibe 6501
UVW 2800 lbs
GVW 3800 lbs
tongue around 400 lbs.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
01-29-2016, 12:05 PM
I think your RGAWR is 3900, and FGAWR is 3700.
01-29-2016, 12:07 PM
I have a 4X4 so the numbers would both be 3900. Apparently I read the chart wrong and must have posted what it has listed as the base weight of each axle. Sorry for the mistake.
01-29-2016, 12:10 PM
Get this....
My truck is the 145" WB with a 5.0L Coyote V8 and a 3:31 diff
The chart sez I can tow 8100 lbs.
http://www.ford.com/resources/ford/g...rv&tt_f150.pdf
That's a load, but not the kind of load you're thinking of.
If I go to a 3:55 RE, it says I can pull 9,500. Say what? All that more for just a little increases in differential?
Okay, now get this -- In an EcoBoost with the same configuration, 3:31 axle, etc, it sez you can pull 9,500 lbs.
Hokay...... The EcoBoost is a strong engine but it isn't that much (if any) stronger than a Coyote V8...... BUT, if you go to a 3:55 differential, it only increases your towing from 9500 to 9800.
Something ain't right. It makes no sense. Everything else is identical as far as I can tell.
Same frame, same 9-3/4 inch rear end... Unless Ford was putting some 8.8 rears on the 2013....?? But I have the 9-3/4 on mine.
And Ford ain't like some of the others -- They don't make 100s of combinations. They usually just make one frame, one transmission, a handful of engines.
It's their 'modular' approach designed to keep costs down.
What I think is that a lot of these towing guides are just that -- Guides. And that they just kinda guessed at some of them
01-29-2016, 12:13 PM
2013 Ford F 150 5.0 XLT 4X4 Reg cab 8' bed
3:73
Towing 9700
GVWR 7250
RGAWR 3850
FGAWR 3600
Payload 1978
POS-Affirmative
01-29-2016, 12:24 PM
GVWR 7,700
Rear GAWR 4,050
Front GAWR 3,900
Payload 1,822
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
01-29-2016, 12:27 PM
Just A Member
GM specs for my truck listed below which is a fully loaded LT EXT cab 4x4 model
Silverado 1500 offers a comprehensive array of features that make it an excellent choice for towing and hauling, including:
- StabiliTrak with trailer sway control and hill-start assist
- Tow-haul mode for automatic transmissions
- The new-for-2013 powertrain grade braking (both in and out of tow-haul mode)
- Available Integrated trailer brake controller
- Available max trailering package (10,700-pound / 4,853 kg maximum trailer weight rating)
- Available rear vision camera.
When equipped with the available max trailering package and the 6.2L V-8, the Silverado 1500 can tow up to 10,700 pounds (4,853 kg).
6.2L V-8 (L9H), with E85 FlexFuel capability, an aluminum block and variable valve timing, rated at 403 hp (300 kW) and 417 lb.-ft. of torque (565 Nm).
NHT – Designed for maximum towing capacity; it includes monotube rear shocks, 17-inch wheels and off-road tires, and high-capacity rear springs.
I pull a 35 foot TT
Tongue weight 980 lbs
Dry TT weight 7200 lbs
GVWR 10200 lbs
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
01-29-2016, 12:45 PM
Just A Member
Actually I have not seen anyone else on this forum that has one of these trucks. If someone does let me know how you like it. I ordered this new specifically for towing but I wanted a half ton because most of the time I drive it I am not towing.
Ed & Brenda
01-29-2016, 01:34 PM
2006 Ford F150 Super Cab, 4x4, 6.5’ bed, 5.4L Triton engine, 4 speed automatic, 3.73 final drive gears.
GVWR: 7200 lbs.
FAWR: 3750 lbs
RAWR: 3850 lbs.
Tow Rating: 9300 lbs.
GCWR: 15,000 lbs.
Listed Payload: 1632 lbs. (per door sticker)
Trailer: Surveyor 263, 28.5’ long, travel weight ~5500 lbs. with a ~700 lbs tongue weight travel ready.
Typical gross traveling truck weight is 6800-7100 lbs., depending on whether generator, bikes, and canoe (with rack) system is taken along with usual gear.
01-29-2016, 01:46 PM
Originally Posted by The Big Toe
Get this....
Gear ratio will always play a much larger role in the towing capacity of a naturally aspirated engine versus a forced induction. The torque curve comes on at much lower RPM with the EB than the 5.0 meaning less torque multiplication is needed from gear reduction. And, yes, the EB is significantly more powerful than the 5.0 at typical towing RPM's.
01-29-2016, 01:54 PM
HEE HEE.
01-29-2016, 02:08 PM
If you're not familiar with the Coyote V8, I can't say I blame you; what with all the (well-deserved) hoopla over the EcoBoost.
But the 5.0 is no slouch.
The Eco doesn't catch the 5.0 until 2,800 RPM and the 5.0 still makes 300 lb-ft of (dyno) torque at 3,500 RPM, which, for a DOHC Engine that RPM is nothing. Nothing.
For a pushrod Engine? Yeah, that's huffin' & puffin'
Not so much for an OHC engine.
whatever
I'm just saying that those tow charts are not what they appear. They really want you to spend the extra bucks on doo-dads you don't need
01-29-2016, 02:20 PM
Your chart is completely bogus. Well documented that dyno'ing the EB is very difficult because of the twin turbo setup. Look at the rating above; 420ft. lbs at 2500, whereas your chart shows just over 200 ft. lbs at 2500. I know the thought of a V6 being a better towing machine than a V8 is difficult- I was a naysayer originally, too and a die hard V8 guy. But the simple fact of the matter is that the EB is a MUCH better engine for towing. It hums along effortlessly when V8's would be screaming and downshifting. The Coyote engine does have benefits over the EB, but towing capability just isn't one of them.
Edit: What we really need is for someone to hook up an 8K TT to an EB truck and set the cruise at 65 down a road with moderate ups and downs. Then hook the same rig to ANY NA V8 engine. Compare the downshifts required and the RPM's needed to pull hills. You'll find that the EB produces power MUCH lower and requires fewer and less aggressive downshifts. If someone takes this challenge, make sure to get both to full operating temp for the filming as it makes a huge difference in my experience with a forced induction engine.
2014 F150 Super Cab 4X4 8' Box (163" wheel base ) 3.5L EB w/6speed trans & 3.73 gear.
GVWR 7700
FAWR 4050
RAWR 4050
GCWR 17,100
Payload 1780
Trailer GVWR 7574
Don't worry about the mule, just load the Wagon!
2015 Grey Wolf 19RR (Wagon )
2014 F150 XLT ECO Boost max tow (mule)
01-29-2016, 02:38 PM
Out of Order
2015 Ford F150 2.7 ecoboost
Front GAWR 3450#
Rear GAWR 3800#
GVWR 6900#
GCWR 13,300#
Max Tow weight 8000#
3.73 rear end
Payload 1531#
01-29-2016, 02:41 PM
K&N Engineering says you're wrong on the Torque numbers.
And they have a Dyno.
What We're Testing This Week: 2011 Ford F-150 EcoBoost 3.5-liter V-6 - PickupTrucks.com News
The Coyote V8 is making 88% of its maximum torque at 2,250 RPM while the Eco is struggling to make enough to run the A/C. That ain't half bad.
The Eco blows by it at around 2,800 RPM Torque-wise (making 80% of its max torque) but that's to be expected.
I'm not overly impressed by DynoJet but the numbers, run by an independent and disinterested party are hard to argue with.
Manufacturers been known to sell some Snake Oil, too.
Like on the Fuel Economy deal. The Coyote gets MUCH better Fuel Economy than the Eco. Not even close. Anybody that owns one will tell you.
I get 17 around town and an honest 23 on the Highway. If I stay out its @$$. The Eco can't touch that. In fact, that's the #1 complaint against them. Their fuel economy
Is the Eco a better engine? I'm gonna say -- Yes. Newer, hi-tech, the wave of the future.
But the Coyote ain't nothing to sneeze at. Not knocking the EcoBoost. No way. Good motor. Just sayin'
