Old 03-06-2015, 07:10 PM   #1
Chillbilly's Avatar
Power ???
Ok, I parked my 5th wheel in a very remote area which has no AC. Now my trailer battery is dead. I have no way to charge it and have no jumper cables. When I hook up the truck to the 5th wheel, will I be able to raise the legs?
Chillbilly
2013 Rockwood Signature Ultra Lite 8244WS
2015 Ford F250 Quad Cab w/6.2 Engine
Chillbilly is offline   Reply With Quote
Old 03-06-2015, 07:11 PM   #2
fx2
You should be able to once hooked up to the TV
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 03-06-2015, 07:20 PM   #3
I think most all trailers come with a manual over ride like a crank handle to raise them manually look thru your books.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 03-06-2015, 07:23 PM   #4
Another idea you could remove your battery from your truck stick it in the trailer to move the landing gear then put the battery back into the TV.
Mike, Lisa and Jake
Old 03-06-2015, 07:24 PM   #5
Oaklevel's Avatar
X2 you should have a manual crank for when the motor or / battery fails but hooked to the truck the legs should work again as well.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-07-2015, 10:42 PM   #6
My battery has died twice on my trailer from leaving a light on inside. Plugging in to the TV immediately puts power to the electric tongue jack.
Backcountry is offline   Reply With Quote
Old 03-08-2015, 12:14 AM   #7
Fulltime family RVer
Maybe, maybe not. It depends on how dead the battery is. I had an occurrence last year when a delivery driver came to get my camper. I forgot the keys and the battery was dead- he was willing to haul it without a battery, but we couldn't get the legs to raise/lower.
Mine from last year:
Camper 9/11 - landing gear isn't working
On edit, the weird thing is- with NO battery, I can use the pigtail from the truck and then they work fine. It was just this really depleted battery that caused issues.
Old 03-08-2015, 08:52 AM   #8
Timex's Avatar
Just be sure you are hitched up good and don't have a situation where you become unhitched. If the trailer battery is dead, the emergency brakes will not work. The insurance company might not like that idea if a claim were to be filed.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 03-08-2015, 10:49 AM   #9
Jim34RL's Avatar
I posted this on your entry (thread) on another site.
On my first 5er I was learning all but using and storing a 5er. I would put the 5er away in the storage yard after every camping trip and when I went to tow the 5er out the battery would be dead. The electrical parasitic in the camper would drain the battery dead.
What I found out was I could simply plug in the camper umbilical cord to the truck’s 7-way plug and start the engine and used the alternator with the truck electrical system to rise the legs on the camper with no issues what’s so every. By the time I got the camper home from the storage yard the truck alternator would charge the campers’ battery up enough to power the legs down without be hooked to the truck.
At least on Chevy’s and Ram trucks this will work I cannot say about the ford trucks since I will not use one and have no experience with one pulling a 5er.
I have since learned to have a battery disconnect switch and use this; mine complete disengages the negative cable from the battery.
Jim W.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 03-08-2015, 11:05 AM   #10
Just a question... Is it not common practice to extend and retract the landing gear and position the slide(s) with the TV still connected? Where practical of course.... Since our current trailer is our first with a slide, I figured the slide would be a larger draw on my TT's battery so I've always operated mine while connected to either shore power or to the TV..
Camped: 2017 (Days/Nights) - 30/25
2016 (Days/Nights) - 32/23, 2015 Nights - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
power
