Old 10-29-2014, 07:04 AM   #1
Power Chip
Anyone put a power chip in their tow vehicle? A little checking shows I can get one for $69 that will give me 30 hp and 30 ft/lbs increase. Mine does ok but I would like to get a little more torque out of it and a power chip is a lot cheaper than buying a new truck. Are they difficult to install?
Skippy38 is offline   Reply With Quote
Old 10-29-2014, 08:38 AM   #2
GASPEDDLER's Avatar
Power Chip
I have a BD chip in my sons 2000 f350 diesel that I purchased many moons ago. It has three program settings 40hp 80hp and 110hp. I had it programmed to the lowest setting of 40hp and it is a noticeable difference both towing and just around town. I would be weary of boasting your hp too much especially if towing as these power boosts lead to higher tranny temps. Get a good set of gauges to monitor your temps. My chip just plugs into the processor under the dash.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 10-29-2014, 09:54 AM   #3
TURBS's Avatar
Most newer vehicle respond better to having the computer "re flashed" with better timing table and a/f tables.
"Chips" are old school.
Handheld programers are the here and now.
Turbs
Old 10-29-2014, 09:56 AM   #4
You may want to check with RAMforumz or similar forum as quite a few of the members seem to run chips. You need to be careful of some of the chips as they can give you drive-ability issues.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-29-2014, 10:17 AM   #5
I would also call Got a Ram - 5 Star Tuning and pick their brains. buddy called w/question for his v10, he was on phone forever with them, and they were very polite/informative.
linehaul is offline   Reply With Quote
Old 10-29-2014, 11:56 AM   #6
Chipping a gas engine is basically a waste of money. Diesels are much more modifiable and actually gain something by doing modifications.
Chips and CAI's are nothing more than placebos and a waste of money. IMO of course.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 10-29-2014, 11:58 AM   #7
Turbs
Yeah, that's what I thought. I am not looking for a HP gain, but thought if I could shift the torque curve down a bit I might get better power and towability. Stock my max torque is at about 3600 rpms and towing I am usually running at 1700-2200 rpms. I guess that it warrants ALOT of checking before considering it....
Old 10-29-2014, 12:07 PM   #8
TURBS's Avatar
I respectively disagree.
I re flashed my 05 6.0 silverado and observed and calculated a 1-2 mpg average gain in towing and a 2-3 mpg average in unloaded scenerios.
That's a big gain imo.
Figure this, unloaded @ 2 mpg over 26 gallons.
That's roughly 50 more miles per tank and at a tank of gas a week over 52 weeks I think the math speaks for itself.
Will you see or feel a seat of the pants feel like a diesel?
No not likely.
IMO it's worth it.
I pulled a hill in Guttenberg Iowa before and after with my 14,000 lb trailer and 2 as able to achieve 5 mph difference tune vs not flat out wot both pulls.
Anybody ever been to Guttenberg Iowa from the south knows the hill.
Turbs
Old 10-29-2014, 08:18 PM   #9
Another vote for 5Star, when it comes to a tuner with a gas motor. Their good people. The tuner program they loaded, did seem to help my 2010 F150. The tranny shifts at a slightly higher rpm, finds the gears immediately when it does shift, and the throttle seems more responsive. Not so much a power gain, as tweaking what's there to work better.
katkt is offline   Reply With Quote
Old 10-30-2014, 06:42 AM   #10
cpaulsen's Avatar
Smile
I also disagree....I used the programmer from Mike @ 5 Star on my V-10 and it really made a difference!
cpaulsen is offline   Reply With Quote
power
