Old 03-12-2013, 12:03 PM   #1
Power jack
I have a 30 ft windjammer. I was useing the power jack and it stop working .. I had to use the hand crank. What happen ????
JAY COWICK is offline   Reply With Quote
Old 03-12-2013, 12:06 PM   #2
Fulltime family RVer
My first guesses would be: low battery power (maybe try plugging into the truck) or a blown fuse.
ependydad is online now   Reply With Quote
Old 03-12-2013, 12:06 PM   #3
another_newfie's Avatar
Check your grounding between the jack and the frame as well.
another_newfie is offline   Reply With Quote
Old 03-12-2013, 02:02 PM   #4
I'd say a blown fuse.
Rick and Linda
Ford F-250 4x4 Diesel
2013 Flagstaff Classic
ldmcmahan is offline   Reply With Quote
Old 03-12-2013, 06:40 PM   #5
H2oski
I vote for the ground. If you didn't clean the paint off the mounting plate and tounge you probably have a bad ground. When I had mine I solve my ground issue by making my own ground wire from the jack to the battery.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
