Old 10-13-2012, 03:19 PM   #1
Pro Series fifth wheel hitch
I have a bumper pull and I am moving up to a fifth wheel. The dealer is going to install a Pro Series 16,000 lb. fifth wheel hitch. Has anyone had this hitch? Is it a noisy hitch? I read one sreview that says the hitch feel like you are being pushed/ pulled. Any info will be appreciated
FWWJR is offline   Reply With Quote
Old 10-14-2012, 07:41 PM   #2
Great Horned Owl's Avatar
The 16K pro series has a latch bar, and can be a bit noisy and jolting. the 20K pro series has regular jaws, and does not cost a whole lot more.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 10-15-2012, 12:31 PM   #3
Helmsey's Avatar
That is what we initially had when we traded up to a 5er. Since then, the dealer traded me for a Reese 30051 Select Series 16K and it has the jaws rather than the bar to capture the pin. Night and day difference to me.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 10-15-2012, 04:09 PM   #4
camper1999's Avatar
I have the 26k hitch and have had no problems with noise. So far it seems like a good hitch. I have towed about 5000 miles on mine in less then a year.
2011 GMC 2500HD Diesel
Old 10-16-2012, 10:48 PM   #5
Thanks for the input. I just learned that the Pro Series has replaced the 16k slide bar with the double locking jaws like the larger unit. The dealer will install the newer hitch. I will see how it goes.
Old 10-17-2012, 06:53 AM   #6
TURBS's Avatar
I wonder if they have a retro fit to update to the new style?
Turbs
Old 10-17-2012, 11:00 AM   #7
I am not sure if the old hitch can be adapted to the new. Then again, I am new to the 5th wheel and have no experience with the hitch. I found out the new hitch was available by calling the mfg. 1-800/632-3290. They can probably tell you.
