Old 02-03-2016, 06:23 PM   #11
You know you have a sway problem when the rear of the trucks starts sliding around . Then compound the issue with no trailer brakes . Been there and don`t care to go back .
Big Red and 30WR is offline   Reply With Quote
Old 02-03-2016, 07:26 PM   #12
Fulltime family RVer
I had a sway event on the highway on my second tow with my pop-up. The only thing I was ever told was to squeeze the trailer brake lever.
It swayed. I squeezed and also let my foot off of the gas pedal. After the sway slowed down, I tapped the brakes and also slowed down.
ependydad is online now   Reply With Quote
Old 02-04-2016, 08:14 AM   #13
Usually Confused Member
emm-dee's Avatar
Originally Posted by fonzie View Post
I remove foot off accelerator, apply trailer brakes only and keep vehicle under control....this is on dry road......
Controlling Sway Causes of poor tow
That's a very informative article.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 02-04-2016, 10:50 AM   #14
firsthere's Avatar
When I first got my dump trailer, the operator loaded 3 tons of gravel way too far in the back. As soon we hit the freeway at about 50 MPH it started swaying pretty bad, I let off the accelerator and luckily thought to apply the trailer brake. It took what seemed like an eternity but it finally stopped swaying. Immediately got off the freeway and took side streets all the way back to to the jobsite. Now I direct them on load placement and even had to dump one on the spot when they placed it wrong.
firsthere is offline   Reply With Quote
Old 02-04-2016, 11:59 AM   #15
mike.t's Avatar
Originally Posted by phillyg View Post
I've never had to stop a badly swaying trailer, but I've always been told to manually activate the trailer brakes with the controller which will reduce the trailer swaying and everything will slow down, getting you under control. It makes sense to slightly accelerate but I question being able to coordinate all the above while your poop hole is contracting.
X2
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 02-04-2016, 01:04 PM   #16
Talking from experience
Last spring had a rear left wheel come off of TV at 100 KPH (55 MPH) while towing 28 foot 5th wheel. Trailer was swaying pin to pin. Instinct kicked in and I accelerated slightly, and gently applied trailer brake by hand Trailer came back behind TV quickly and from there I used trailer brake to bring the combo to a stop.. The wheel coming off broke my TV brake line and we had no brakes other than Trailer brakes.
Scary yes but not until everything get under control.
For minor sway situations I find that accelerating a bit to pull trailer into position followed by gentle braking will work to quickly regain control.
Donfi is offline   Reply With Quote
Old 02-04-2016, 01:29 PM   #17
I agree. Experienced it. Heading down a large hill in eastern OH on I-77 N, traveling at 70 mph, trailer started pushing the truck up to 80 mph very quickly. Acceleration was not an option; let off gas and hit manual trailer brakes hard. It stopped the sway immediately, then I used truck brakes and manual trailer brakes, (mostly trailer brakes to slow both. Yes, pucker effect to the max. Traded 1/2 ton in for a 1 ton.
Cardinal5er is offline   Reply With Quote
Old 02-04-2016, 01:53 PM   #18
I can echo many of the replies so far, foot off the gas and apply the trailer brakes ONLY to straighten up and slow down. While I have never had any RV sway I have experienced trailer sway towing a 20 foot flatbed trailer with a Ford F150 tied down a bit too far back, but nobody thought it was when it was loaded. Going straight and uphills no problem, when I was going down a long grade was when it started to sway. Instant pucker factor +10!! It wasn't severe but it was quick and that was enough! After that it was very, very slow the rest of the grade. I have seen 2 almost disasters over the years, the worst was a pickup towing a full size van on a U-Haul trailer. It started to sway a little and the guy didn't get it and he just kept going 70 so it quickly started swaying more and more and everyone behind him including us slowed way down as the trailer pulled that truck across all 4 lanes and almost over but then just into a 180 before he got it stopped facing all the traffic in the wrong direction.
It can happen so fast you won't have any time to pray!
Tdbrn is offline   Reply With Quote
Old 02-04-2016, 02:05 PM   #19
Best defense is best and largest anti sway bar setup. Accelerate and use trailer brakes. 5th wheel much more stable.
Harkerr is offline   Reply With Quote
Old 02-04-2016, 02:28 PM   #20
Youroo is correct. Apply the trailer brakes manually while accelerating with the TV. Basically you are stretching the hitch point. That should help to pull the rig straight. Once you have regained control is the time to gradually brake. Braking with the TV will only only amplify the sway especially if the brake controller is set on the light side. You may also have to steer into the slide to keep the TV from coming around.
I have had this happen once on flat open land in Nebraska. I was pulling a single axle 21' camper with a HD everything 3/4 ton 4WD Chevy. It was set up properly with a WDH. A rouge gust of heavy wind came broadside on the driver's side. It literally heaved the camper sideways-and the back of the TV with it. If it had been really windy that day, I may have expected it, but it came out of nowhere. I used the brakes on the trailer, accelerate the TV method and it worked. Heart back in the chest and a little TP and we made it home okay. This is the only time it has ever happened. Phillyg, you can do this if your life depends on it.
Actually, this is something you should practice for because most often the brake controller is hard to reach and learning in a situation is not prudent. Ford is now putting the integrated brake controller at the top of the dash which really make sense. We will be putting one on our E-450 chassis.
PenJoe is offline   Reply With Quote
sway, vent
