Old 07-13-2015, 03:18 PM   #1
Dad of 2 teenagers...
ProPride 3P review
Moving up from a Toyota Van pulling a pup to a SUV pulling a 30' TT, I decided to go with a ProPride 3P Hitch system to keep my family safe on our weekend trips and on our annual 2000 miles round trip from Montreal to Myrtle Beach.
Knowing my manual limitations, I had my RV dealer do the installation. Problem is that his tech did an amateur job and I finally completed the installation myself (although paying for 3 hrs at $135/hr). At least they had already done the "major" modifications that consisted in moving the propane tanks and the battery.
It has now been over 2 months since I have my new TT and the PP3P and I still have 2 unresolved issues:
1- The weight distribution jacks are made for the wide 2 3/8 in frames while my Wildwood XLite has a 2in frame, causing the jacks to move and bend the side of my trailer's frame. Sean promissed to send me some shim plates a couple of months back but still hasn't acted on his promise...
2- The bottom of the drop hitch bar occassionnaly hits the pavement on uneven turf. My SUV sits lower than the trailer so in order to get a 2in raise, I reversed the hitch bar. The way the adjustable hitch bar is setup, I have bottom part at only 4in off the ground. Currently inquiring on either cutting off the excess or on maybe getting a stinger made by Hensley, if its compatible.
All in all, great product that does do what it promises: NO SWAY. But its still needs some improvement before I can tag this as the "perfect" hitch system... I also have some concerns on their customer service. A lot of emails have gone unanswered (ignored).
If I had to redo this, I would most probably go the Hensley route instead, especially now that I know I need a 2" offset. I guess I just expected more for the money I dished out...
Name:	Car and Trailer.jpg
Bob the frog from Montreal
2009 Flagstaff 227 pup (Sold in 2014)
2015 Wildwood 261BHXL
2010 Mercedes-Benz ML350 Bluetec
ProPride 3P Hitch
BobBaron is offline   Reply With Quote
Old 07-13-2015, 06:36 PM   #2
That's a lot of money to spend and not be happy with it. Call Sean daily until he sends you the shims. You bought it to be safe and currently it doesn't sound safe at all.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 07-14-2015, 11:58 AM   #3
I am fairly certain I have the same 2" frame rails. With mine, I just tightened the U-bolt as it said (ended up going a little too tight and bend the U-bolt just slightly), and then tightened the lock bolt from the back and I have no issues at all as far as I've seen...
I also had to reverse the hitch bar on mine, but I don't have any clearance issues. Might just be the TV clearance though. I would definitely give Sean a call. I had a couple emails go unanswered, but one call and he was right on it with helping me (was just looking for some install help at the time).
klarowe is offline   Reply With Quote
Old 07-19-2015, 06:49 PM   #4
MIKE44460's Avatar
Please don't take offence to this, but pal, you ain't got enough truck. Empty TT 4,314, max towing weight for TV 4,600.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 07-19-2015, 06:59 PM   #5
dannyabear's Avatar
Originally Posted by MIKE44460 View Post
Please don't take offence to this, but pal, you ain't got enough truck. Empty TV 4,314, max towing weight for TV 4,600.
This would be the correct answer; TV wheelbase is way to short for a 30' trailer;plus it is probably unibody and will bend TV with a WD hitch.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-20-2015, 07:40 AM   #6
I built some brackets for the WD jacks on mine after having the issue with them bending outward. Also, I suspect that IF it is properly setup and you are having some issues with the bars dragging it could possibly be because the TV is squatting or porpoising when hitting dips or bumps. Basically the suspension may be too "squishy" to stay at its set height allowing the tongue of the trailer to dip and make contact.
Old 07-20-2015, 07:43 AM   #7
After looking at the pic, I have to agree that your SUV is a little outmatched with that trailer. When you said SUV I'm thinking suburban or Tahoe or expedition. Your TV looks to be some type of compact SUV.
Old 07-20-2015, 11:06 AM   #8
Some precisions to comments above:
1- No offense taken. I know I'm stretching the limits but I'm trying to do it the safest way possible We have no ambition to go with a bigger trailer in the near future. If anything, we will downsize a few feet when the teens stop tagging along.
2- The TV (a Merc ML) is rated to tow 7,200# not the 4,600# that was wrongfully stated. The TT sits at 5,700# once packed. Tongue weight is just under 700# including the Propride 3P hitch system attached with stinger. I have also reinforced the TV receiver as its tongue weight is originally rated at 600# by Merc.
3- The bottom of the Hitch bar touches the ground because the PP3P adjustable stinger is too long and not because of suspension issues. (see pict below of a similar setup to mine). And it does not hit the pavement because of TV bounce but because of road being uneven: Speed bumps higher than 4" for example.
I am thinking of having the "excess" bar sawed off, which would give me an extra 2" of clearance, solving most scaping issues.
So in short, the hardware is the issue here (WD jacks + adjustable stinger length) not the ride! Stay focussed guys... But I do appreciate all of your comments (and I understand your concerns)
ProPride 3P Hitch
Old 07-20-2015, 07:29 PM   #9
jlgail4309's Avatar
CALL Sean on the phone. I believe he will help you though your problems.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 07-20-2015, 08:19 PM   #10
Tongue weight rating is not solely based on receiver strength, it also takes into account the frame mounting points and suspension components. Your car has to "catch" that 700lbs. each time you hit a bump and the inertia that is generated. Highly recommend you check the receiver and frame often. Do not tie break away switch cable to any part of your receiver only to frame components for the safety of others. Not saying it's going to fail but... Hensley hitch bar is not compatible with PP3P they very similar but the PP3P is larger where it wedges into main hitch assembly.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
propride
