Old 03-20-2013, 07:50 PM   #21
Dave_Monica's Avatar
Originally Posted by LSUTiger View Post
Took a closer look at my 4 point hitch today and for some reason the dealer had the brackets on the tongue of the trailer set diffrently. On driver side had two holes on the top left open and on the passenger side had one hole at the top left open. Any reason as why this would be? I recieved my scale in today to measure tongue weight. I am right at 700 lbs. Next thing I am going to do is get to the scales.
Travis
No reason for the brackets to be set different...unfortunately not a good sign that the hitch is set properly. The tongue weight of 700 lb is with the camper loaded for camping?
With a listed dry weight of 5773 lb, your camper could be as much as 7000 lbs ready to camp. You should shoot for a tongue weight 850 to 900 lb. You may have to shift some heavy gear to the front pass-through or under bed storage. If you have payload capacity to use, tongue weight is your best friend in terms of sway control.
Dave
Old 03-20-2013, 11:02 PM   #22
jlgail4309's Avatar
Travis
Should be the same on both sides. On the web site the have a install guide with step by step on the hitch install.
Equal‑i‑zerŪ hitch dealer in your area or Progress Mfg. Inc. customer service
at 1-800-478-5578 or by visiting Equal-i-zerŪ Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
