Old 12-04-2013, 08:57 PM   #1
muddyrode's Avatar
pull rite super glide question
Dose anybody ever have there super glide hitch move around
when Not hooked up to a trailer?
mine bangs around back there when going around corners in town
does anybody teather theres down?
muddyrode is offline   Reply With Quote
Old 12-04-2013, 09:04 PM   #2
I have a super glide and talked to the factory rep at the Hershey RV Show. He said the stop bolt on the front of the slider should be adjusted so that it almost takes two hands to knock off of center. Mine is not quite that tight but still snug enough to prevent it from moving around while not hooked up.
Paul
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 12-04-2013, 09:53 PM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
Paul
X2...make your adjustment at the jam nut as mentioned & it'll stop the movement
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 12-04-2013, 10:20 PM   #4
X3. Mine would move around some before I made the adjustment on the jam nut. It also stopped some mild banging noises my hitch was making when I would stop and start from a light, etc.
2012 Palomino Sabre 32BHTS
2008 GMC Sierra 2500 SLE 4x4 Duramax
clange is offline   Reply With Quote
Old 12-04-2013, 10:30 PM   #5
Herk7769's Avatar
Here is the manual and the adjustment procedure.
Name:	Cam Adjustment.jpg
Lou and Laura - Shopping for a Camping Buddy
2008 GMC Sierra 30000HD Crewcab SB Allison Duramax
HAM CALLSIGN - KC3FFW
Old 12-04-2013, 10:33 PM   #6
themounties's Avatar
This is why I love this place mine does this too and I'm gonna give this a try thanks
themounties is offline   Reply With Quote
Old 12-04-2013, 10:51 PM   #7
1surveyor's Avatar
I guess that I need to do this adjustment to mine thanks guy's
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
1surveyor is offline   Reply With Quote
Old 12-06-2013, 07:55 AM   #8
muddyrode's Avatar
thanks for the info Kmac
Old 12-06-2013, 10:12 AM   #9
avolnek's Avatar
My father's hitch still rocks around even with the jam nut "hand tight" He does tether the head on each side to the front corners of the box to prevent it from sliding around while un hooked. Tightening that jam nut too much will only prematurely wear that roller and nylon block out. I'm sure we can tighten his some more yet but he doesn't experience any noises while towing so I feel that he is set where it needs to be...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 12-06-2013, 04:06 PM   #10
I also have a Pullrite hitch and was recently asked to move somebody elses fifth wheel RV that does not have a Pullrite catch plate. Can I do that with the Pullrite slider ?
Mr.z is offline   Reply With Quote
