Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > Towing, Hitches & Toads
Old 01-31-2012, 01:52 PM   #11
Originally Posted by flyrotor
I agree, way too much trailer for the suburban.
I previously had a suburban to pull my trailer, which is much lighter and shorter than either mentioned, my GVWR is 7680, and probably closer to 6800 pounds fully loaded, it was within the specs of towing with the suburban, but I did not like the lack of power, the transmission temp (even with upgraded HD trans cooler), the shifting of gears, etc. The frame, suspension and handling with the trailer did fine,
I upgraded my TV and never looked back....
What did you upgrade to for a TV? Also, what is the GVWR on your trailer? I should have picked the TV first.
bmcgee is offline   Reply With Quote
Old 01-31-2012, 11:33 PM   #12
we have the Yukon xl denali (6.1 v8), and pull an 8313 that weighs in around 7k. its about at the limit for the Yukon. frankly the biggest issue I have is tongue weight (the amount of weight directly on the hitch). the airbags run forever levelling the truck.
we will probably goto a 2500 model Yukon xl when we are ready to upgrade the tv.
spinningbull is offline   Reply With Quote
Old 02-03-2012, 02:25 AM   #13
flyrotor's Avatar
I bought a Dodge 2500 6.7 Cummins Diesel, 6 speed manual transmission. The GVWR on my trailer is 7695.
I always owned 1/2 ton SUV's because of 5 kids, but now 2 are out on their own, one is only with us on about 1/2 the trips. But the Dodge with the manual transmission has the split seat in the front, which means no center console, this allows for seating of 6 in seatbelts.
Depending on their size, this would work for you even though it's tighter than having that 3rd row seating.
Another bonus, I have the 8' bed, tons of room for all the extras that I don't need/want to put in the trailer for travel.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 02-06-2012, 07:47 PM   #14
mindenglock's Avatar
We bought a 2011 F-250 just for travel with the kids. The rear seat is HUGE... more room than the front seat! The new 6.4 diesel will pull anything you hook to it and pulls my 318BHS like a lawnmower trailer. Put a bed cover over the back and you have a monster TV with plenty of room for kids and lots of dry storage.
mindenglock is offline   Reply With Quote
Old 02-07-2012, 01:26 PM   #15
I'm looking to go from a popup that is about 20 ft long to the 318BHS. How much of an adjustment is it to pull something 35 ft long? Is it a real adjustment pulling down the road and also trying to get into camp sites. Do you pull your trailer on long trips or stay close to home.
Old 02-07-2012, 01:34 PM   #16
Moderator
mtnguy's Avatar
I went from a 20' Trailmanor to a 28.5' conventional trailer. I can't get into some of the camping sites now that I liked with my Trailmanor. My mileage also went south with the new camper........mid 15s with the Trailmanor, low 11s with the current camper.
Make sure you have enough vehicle to safely tow a 35 footer before signing the papers.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is online now   Reply With Quote
Old 02-07-2012, 02:02 PM   #17
We usually stay within 4 hrs of home, but only because of small kids and time constraints. We will start longer trips this year. I have pulled and backed up boats, flatbeds and cargo trailers my whole life so the TT is not that difficult for me. I can usually put it anywhere I want it, but I have looked at a few camping spots and said "No Way!"
I went from a Nissan Titan, which would get the job done, to the F250 which was built to do this. Extendable mirrors, memory trailer brakes, etc. This made pulling the trailer FUN to me. 70mph is a breeze and I have comfortably hit 80 a time or two when not paying attention. Mileage is around 13, but if you watched yourself, I have heard 15 is possible while towing. I did add a set of air bags to the rear just to level everything out when the load is heavy in the bed.
Old 02-07-2012, 05:31 PM   #18
rracer5's Avatar
As you can see by my signature, I feel that my TV is at its max (only because of the engine) for my TT. The TV has a GVWR of 8600. The suspension is not taxed at all when all hooked up with the WD hitch (even when I throw the 800 lb. Golf Cart in the bed). The ride and handling is excellent but, when an uphill comes up, I have to be on top of things to keep the engine RPM's in check. and i will loose a lot of speed on inclines (my choice so as not to tress the engine and tranny too much). The TT is advertized "dry" at around 7100 lbs., so figure in gear, clothing, food, pots, pans etc., Tv's, propane, battery and oh yea......beer & ice, and it's probably close to 9000 lbs. at 34' 10". Since we purchased it, we have taken it on local trips, Myrtle Beach 3 times and New Hampshire 1 time all without a hitch (no pun intended).
As I've said, the TV "handles" very well but, I wish I had more motor. I will be upgrading the TV in the near future keeping in mind an upgrade in TT maybe a few years after that.
2011 RAM 2500 HD 6.7L CTD Crew, Reese Dual Cam Sway/Equalizer
2011 Lacrosse 303 RKS
Nights Camped;
2009 - 56, 2010 - 71, 2011 - 91, 2012 - 14
rracer5 is offline   Reply With Quote
Old 02-07-2012, 05:45 PM   #19
too fast turbo sled
f1100turbo's Avatar
I used to pull my 31bhss flagstaff with my 1999 1/2 ton chevy 4x4 suburban with NO issues EVER ! by the way I towed it for 6 years !
some people are just to picky !
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 02-09-2012, 06:25 PM   #20
I am pulling a Lacrosse 318 with a '10 F150 Screw with a 5.4l without any problems. I have the max trailer tow package and it is rated at 11,200#. Of course the dealer didn't set my Equalizer hitch with enough weight on the bars, but that has been corrected. I probably could use a little more hp when on the interstate but we manage just fine.
2012 Lacrosse 318BHS
2010 F-150 Max Tow
21C1 is offline   Reply With Quote
» Online Users: 607
128 members and 479 guests
0721SSROO, 4bnabird, 4kmprs, Army-dude, B47, backpacker3, bdn56, Bigmatt, bka4tcu, BlakeB, bob213, bob34787, BOBFIDY, Bobhaus, bojack, Brendan, buccello, camperman62, campfun, caper, capucine, Cards1989, Cascade Bob, cgsparks1, Cincy6, Cowracer, crazycampers, DAISY BOYKIN, dashonthedash, dasimser, Dave_Monica, ddemme, depo, dirtman7, djorgensen3, dumptrk, elind, Falcon35, feerobk, Filthy Beast, Fire Instructor, fivecodys, FreedomTracker, fz_sledhead, GarthJ, GaryRudolph, GeneOB, GinaBruce, gredmer, grhodes50, Happy Campers 79, hark582, hokiecampers, hotrodj125, Iggy, Itsthetwoofus, J R, JAJ73, jes520, jrlehr, jwakeman, KarenS144, kick, kixonrt66, KKapa, ktkoch, KyDan, Laura, lazyb1626, lochsa, LuckyMcBRIDE, Mad4sax, maggiek, mamentt, mark250, melbornj, Mpwelch50, mraynie, mrores, mrscot, mtnguy, myredracer, Notuck, nuisance, Old car, Old Jeeper, oldiescc, onthelake, padave65, papap, pappcam, Pharmofish, pick, PrairieBoy, rawlus, ResQMoore, RickV, RJHuser, rockin'ray, ronhanson, rstoro, rweier, sail2liv, scroses40, SDENN4281, sledhead77, softwarejoe, Taranwanderer, Timex, Titleguy, Tjah, tmmar, tojo70, travyp, treadwelll, Triguy, trudinator, T_LMurphy, unhcharger25, venturetaz, VinceU, vlite2011, wagon52, Warrior, Waterfowlwarrior, wayward1, Westernflyer, yworrydog
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
