Old 05-10-2015, 09:13 PM   #11
Left Coast
Originally Posted by tedstr View Post
X2. When I removed my Pullrite hitch this winter I noticed that the trip lever small cylinder was bent and had a small crack. Notified Pullrite and they sent me a new part with washers and clip. Free. Excellent service.
You do get around!
Old 05-10-2015, 11:01 PM   #12
Hmm don't know if I could remove the hitch. Can you see yhe Crack without removing the hitch.
stormy2000 is offline   Reply With Quote
Old 05-10-2015, 11:12 PM   #13
x2 I adjusted mine according to the manual after the first year, the 2nd was fine
Big Bill is online now   Reply With Quote
Old 05-10-2015, 11:16 PM   #14
Jeffco, MO
tedstr's Avatar
I take the top half off by removing the two pins that hold it on. Turn it over to examine the underside and clean if necessary. I do add a little lithium grease and cycle the locking mechanism several times. You can then easily examine the tripping lever for wear and condition. Using the manual parts list diagram the part A, Fifth Wheel Plate Assembly can be easily removed. When you turn it over you will see how the mechism works and the tripping lever (Cam) that I replaced. I have the 15K model, but the other models should be similar.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 05-11-2015, 12:54 PM   #15
Tks for info will ck manual and ses if i can spot anything.
Old 05-11-2015, 02:25 PM   #16
Jeffco, MO
tedstr's Avatar
Pull-rite Hitch Mechanism
Here are two pictures of the hitch mechanism and the trip lever. The small cylinder on the trip lever was bent and there is a small crack on the bottom. Hope this help explain my previous message.
ID:	76692   Click image for larger version
Mary & Ted
Old 05-11-2015, 06:10 PM   #17
Tks for pic
pullrite, towing
