05-08-2015, 12:02 PM
Pullrite super glide towing
When we first got it was great..pulled our SB 31RK so easily. Yesterday returning home it seemed like stopping or starting up after stopping it seemed like the glide was sliding either forward or backward. Going check also with pullrite but wanted to see if anyone experienced this? Thanks
05-09-2015, 08:05 PM
bigdaddy1
Keep us informed on what you discover is the problem. I have a 4400 super glide hitch and so far have not had a problem like you talking about happening. Mine is smooth in operation while towing and stays put when not hooked-up.
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2019 3350RLX
05-10-2015, 06:05 AM
Camper Less Camping
Sounds like you need to adjust the slack via the jam nut that is on the front of the hitch, this will eliminate the play you're feeling.
My former setup used a Pullrite and I had to a adjust a couple of times a year when I felt the bumping when taking off or coming to a dead stop...it's no big deal...great hitch!
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
05-10-2015, 11:15 AM
No reply yet pullrite. . Will update when they reply. Will ask them about adjusting the jam nut to see what say about that too. Tks
05-10-2015, 01:18 PM
Pull rite issue the the stop bolt and lock
I had the same problem the adjustment bolt and jamb nut were not tight on mine so read the manual
You adjust the bolt out so their is resistance for the hitch to turn left or rite. After I did this the problem went away when my hitch was installed they did not secure the jam nut or make the ajustment. The hitch started to move and bang when the fifth wheel was not connected
05-10-2015, 02:40 PM
Stormy 2000 Cajun Po Boy and Cal 1951 are dead on right. It's easy to adjust and and it won't bang anymore. You don't have to have the trailer hooked up The hitch plate will have to much play. You adjust it till it feels right.
05-10-2015, 06:49 PM
Pull rite hitch
I agree you just need to adjust the slack. I have a 2700 and had a issue with lubrication. The pullrite customer service was excellent. I would email through their web site. You can also down load users manual.
I am considering replacing my 2700 with a 4100 because it is about 5" lower and my 5th currently does not tow level.
05-10-2015, 08:03 PM
had the same issue. Tighten the adjuster so that you can just barely rotate the hitch by tugging on the handle. This seems tight but will last well and take out all the clearance.
05-10-2015, 08:54 PM
Left Coast
X2
05-10-2015, 09:03 PM
Jeffco, MO
X2. When I removed my Pullrite hitch this winter I noticed that the trip lever small cylinder was bent and had a small crack. Notified Pullrite and they sent me a new part with washers and clip. Free. Excellent service.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
05-10-2015, 09:13 PM
Left Coast
You do get around!
05-10-2015, 11:01 PM
Hmm don't know if I could remove the hitch. Can you see yhe Crack without removing the hitch.
05-10-2015, 11:12 PM
x2 I adjusted mine according to the manual after the first year, the 2nd was fine
05-10-2015, 11:16 PM
Jeffco, MO
I take the top half off by removing the two pins that hold it on. Turn it over to examine the underside and clean if necessary. I do add a little lithium grease and cycle the locking mechanism several times. You can then easily examine the tripping lever for wear and condition. Using the manual parts list diagram the part A, Fifth Wheel Plate Assembly can be easily removed. When you turn it over you will see how the mechism works and the tripping lever (Cam) that I replaced. I have the 15K model, but the other models should be similar.
Mary & Ted
05-11-2015, 12:54 PM
Tks for info will ck manual and ses if i can spot anything.
05-11-2015, 02:25 PM
Jeffco, MO
Pull-rite Hitch Mechanism
Here are two pictures of the hitch mechanism and the trip lever. The small cylinder on the trip lever was bent and there is a small crack on the bottom. Hope this help explain my previous message.
Mary & Ted
05-11-2015, 06:10 PM
Tks for pic
