Old 04-02-2013, 07:41 AM   #1
Question Pullrite Superglide and Super Rail Question (Yes another)
Hi Guys & Gals
I have seen various posts...but no real solution...and maybe there isnt...
BUT....
I just installed the Pullrite SuperGlide with Super Rails in my 2011 F350.
I love the hitch and the unobstructed bed when removed....has anyone found plugs that look and fit well in the holes in the bed of the truck when the hitch and rails are removed?
tromler is offline   Reply With Quote
Old 04-02-2013, 07:57 AM   #2
slide5r4fun's Avatar
Not sure of the proper name of the part but Ford sells a bumper plug that is supposed to fit the holes in your bed perfectly. I plan on getting some to see if they work, just haven't gotten around to it yet. The Ford part # I was given is XL3Z17D754AAB.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
slide5r4fun is offline   Reply With Quote
Old 04-02-2013, 07:57 AM   #3
Dave_Monica's Avatar
How big are the holes? A body shop supply house will carry various sized hole plugs.
Dave
Old 04-02-2013, 08:26 AM   #4
Thanks Guys, the holes are 1.5" (a little elongated), but I think I found some rubber automotive plugs that will fit. The only downside is that the holes are not 100% on a flat part of the truck bed, they are off center from the raised ridges in the bed, but i think this will be a solution none the less.
Old 05-29-2013, 12:00 PM   #5
hi yes .you can get them from ford they have the plugs
wire1946 is offline   Reply With Quote
Old 06-02-2013, 07:44 PM   #6
jevanb's Avatar
you could buy some extra pins and cut off the tops and install into the holes, grind in a flat blade screwdriver slot to remove
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
