Originally Posted by dustman_stx
Timing chains were an issue with the early ones. Don't remember when they resolved it, but I do know I researched that when I had my 2013 and it had been addressed. My parents have a 2011 that's got just shy of 190K it with no timing chain issues, though. Turbos are a little over $600 each- this is for Ford OEM new turbos.
It depends on how you drive your truck.
Currently Ford is working on a series of things on these engines (Eco and Coyote), rattle noise, tick noise, knock noise, oil consumption, etc.
You may have none, you may have all of them or something in between.
No manufacturer can test the engine in all possible working cycles so they have a standard one that should cover most uses but certainly will leave others out...
The power density that those engines have used to be only for racing and getting that on mass production for common, long term use is a huge learning curve. Way easier to hit the nail on a big displacement push rod engine but those new ones, too many things going on at the same time.
I remember when BMW came up with DI engines and had to change engine heads at 30K miles... there is a price to be paid to be ahead of the game on technology...
