Originally Posted by thebrakeman
I'm curious about these integrated controllers. If you have the means to make an adjustment (1-10, 1-12, whatever), then it's obviously not fully-automatic. What is the process for choosing the correct setting.
I didn't see that anyone answered your question: The process is pretty much the same as for a Prodigy.
From my 2016 Silverado Owners Manual:
Trailer Gain Adjustment Procedure
Trailer Gain should be set for a specific trailering condition and must
be adjusted anytime vehicle loading, trailer loading, or road surface
conditions change.
Warning
Trailer brakes that are over-gained or under-gained may
not stop the vehicle and the trailer as intended and can result in a
crash. Always follow the instructions to set the Trailer Gain
for the proper trailer stopping performance.
Use the following to adjust Trailer Gain for each towing condition:
1. Drive the vehicle with the trailer attached on a level road
surface representative of the towing condition and free of
traffic at about 32 to 40 km/h (20 to 25 mph) and fully apply
the Manual Trailer Brake Apply Lever.
Adjusting Trailer Gain at speeds lower than 32 to
40 km/h (20 to 25 mph) may result in an incorrect gain
setting.
2. Adjust the Trailer Gain, using the Trailer Gain Adjustment
Buttons, to just below the point of trailer wheel lock-up,
indicated by trailer wheel squeal or tire smoke when a
trailer wheel locks.
Trailer wheel lock-up may not occur if towing a heavily loaded
trailer. In this case, adjust the Trailer Gain to the highest
allowable setting for the towing condition.
3. Readjust Trailer Gain anytime vehicle loading, trailer loading,
or road surface conditions change or if trailer wheel
lock-up is noticed at any time while towing.
