We just completed the pad on the sode of our house to store our trailer. It's made-up of crushed limestone. Is it ok for the trailer amd more specific the tires to sit on this for long periods of time. Curious what others think. Thanks in advance for your response.
Location: Alberta - East of the Rockies, West of the Rest
You can drive the trailer on a couple pressure treated 2x10's to get them off of the damp ground if you want to but most importantly protect the tires from the sun.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
I had my old trailer on a river rock driveway for about 18 months. When I finally did move it I noticed the tread blocks of the tires had dents in them from the rocks. A friend has bluestone drive and noticed the same thing after winter storage. I now have 2" thick 12x24 driveway pavers where the tires sit during storage. A couple cheap rubber car floor mats from walmart go under the tires. Nice and smooth and no direct contact to anything but rubber.
My issue with the wood it can sometimes cup, holds water and then the tire is sitting in water 24/7 during storage.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
I also park mine on rubber pads. I got mine at Harbor Freight. The alkalinity in the concrete/stones can affect the rubber in the tires. I feel rubber to rubber is better.
I park my Georgetown on a concrete pad. What I do is start the generator on the first of the month, for 10 minutes. I then start the engine and MOVE the motorhome back one foot so the same rubber is not sitting in the same spot. Problems solved.
Doing that also helps avoid "dish rattling" flat spots that can take miles to work out on some tires when you take them out for the first trip of the season.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
Get something like this product for long term storage.
I had a set of 4 yellow plastic ones for our 2 trailers. sold one trailer and kept the set for it. I screwed them onto a 2x10 Pressure treated wood and roll up onto them when winter is coming.
also don't forget to cover the tires over to protect against the UV rays and dry rot.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
