Old 05-20-2014, 10:18 AM   #1
thestrangebrew's Avatar
Question about weight dist. (not wdh)
Just a quick question about loading a trailer up. As I understand it, the axles act as a fulcrum right? So any weight I put in front of the axle will add weight to the hitch to get good tongue weight? Or do I need to put everything as front as possible to get more weight on the tongue? Sometimes I feel like I'm over analyzing things but just want to be sure and safe. Thanks.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 05-20-2014, 10:31 AM   #2
TURBS's Avatar
Weight ahead of axle puts more weight on hitch.
Weight behind axle removes weight from hitch
TURBS
"Sabre owners united"
Old 05-20-2014, 10:37 AM   #3
TURBS
Thanks. That's what I thought but wasn't 100% sure.
Old 05-20-2014, 11:06 AM   #4
indybp57's Avatar
Your TT is probably well balanced as it came from the dealer. Any significant added weight should be placed just in front of the axles - not too far forward. This will help maintain the 10-15% rule for tongue weight.
Sent from my Kindle Fire using Tapatalk 2
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 05-27-2014, 11:12 AM   #5
thebrakeman's Avatar
Weight placed half-way between any 2 axles will be split evenly between those 2 axles. The closer it is to any axle, the higher proportion of it's weight will go to that axle.
So, a 30lb propane tank (close to the hitch on the tongue) will have more effect on TW than 30 lbs of stuff in a forward holding compartment (in the camper). So if you are trying to increase TW, you want to add weight as far forward as possible.
But if you must add some weight, but don't want to impact TW, try to keep it close to the axles.
If you must add some weight, and would like to decrease TW, put the weight as far behind the axles as possible.
thebrakeman is offline   Reply With Quote
Old 05-27-2014, 11:41 AM   #6
Herk7769's Avatar
Remember your "target" is to have about 12% of the TOTAL weight of the camper on the tongue BEFORE you put the WD bars on.
Here is a good way to measure your tongue weight as you load up.
Just remember to use the correct distance from the hitch post to the scale or you could break your scale.
HAM CALLSIGN - KC3FFW
weight
