Old 03-13-2013, 05:13 AM   #1
Toy-aholic
question for B&W Patriot owners
I just installed a Patriot 16k in my 3500 long bed and need a rough idea where I should have the fore-aft and up-down adjustment for my new Crusader I'm picking up next wk. I measured the distance between the cab & center of the pin latch & is over 4'. I have it set all the way forward & 1 hole up from the bottom. Does anyone have a similar setup?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 03-14-2013, 06:02 AM   #2
golfmedik's Avatar
It is really trial and error! With you having a long bed, you will not have cab clearance issues at all. However, you may have bed clearance issues between the top of the bed and the bottom of the 5er. If it were me, as deep as the Chevy's beds are, I would put it all the way up just to get it home from the dealer. You generally should have 6" clearance between bed and 5er from the top of the rails. I would do it that way and see how see pulls, looks(as far as towing level) and feels while pulling her home. Then if you need or want to change it later you can, but you won't be too close for comfort on your way home.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-18-2013, 02:45 PM   #3
golfmedik's Avatar
Send us a pic with the new camper and your new B&W hats!!!!
