Old 06-19-2016, 09:44 AM   #31
Originally Posted by northstar1960 View Post
the chevy 2500 6.0 i think all come with 4.10 rear ends . as far as running at 4200 to 4500 rpm pulling passes . no problem the 6.0 can run all day like that . 4500 rpm is not that much for a gasser and never feels like it can't handle it or anything even close those that do get that feeling don't know much about trucks or gas engines . i pull my xlr29hsf toy hauler weighs in fully loaded at just over 9000 lba with a tw of 1200 the 2500 hardly knows it's back there . i use the andersen wdh and never any issues with sway or bounce the unit tracks as one with the truck . mpg not towing is a low of 13 and a high of 15 depending on how you push the peddle . towing is 8.5 low and normal 9 to 9.5 . i only have the 4 speed and wish it was the 6 but it does the job from Colorado to Fl and Fl to Colorado to montana and back again . never misses a beat at 138,000 mile i will look to up grade in a couple yrs . the 6.0 is a 300,000 mile engine . just change the oil
We ordered our "2500HD 4x4 in 2013" with "3.73 gears" and it has 3.73 gears! Youroo!!
Old 06-19-2016, 10:02 AM   #32
Oklahoma Proud
MillerTime's Avatar
There was a time when all you could get was the 4.10 gears with the 6.0 in a 2500 or 3500. I think after switching to the 6 speed 3.73 was optional.
We have looked at one truck with 3.73 gears and i think they will look at another i found with 4.10 gears on Monday.
I think the 4.10 gears would be optimal for their situation.
Old 06-19-2016, 03:55 PM   #33
northstar1960's Avatar
you can see by the posts 4.10 is the common suppose you can order different then what one would want when towing . i can see the 3.73 with the 6 speed .before when all you could get was the 4 speed 4.10 gears was the norm and is still the best for towing
northstar1960 is offline   Reply With Quote
Old 06-23-2016, 01:03 AM   #34
I have a 2015 2500HD. I load a Honda Goldwing motorcycle in the bed of it and pull a Catalina 333RETS which is ~8k lbs dry. I have had no problems towing through the West Virginia and North Carolina. Mileage was ~8 MPG at 62 MPH. The truck is quiet and easy to drive. I do put it in manual mode to allow me to set the maximum gear it will go into. (For engine braking going downhill and to prevent it from hunting when on the level.)
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
truck
