Old 06-04-2016, 02:44 PM   #21
phillips's Avatar
Originally Posted by lbrjet View Post
What is the point of lifting the front end? Never heard of that before.
A 1/4 inch rise in the front seems set up is pretty good, hardly ever gets exactly back to equal.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
So truck sits level front to back.
Sent from my SM-G900W8 using Tapatalk
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
phillips is offline   Reply With Quote
Old 06-04-2016, 02:46 PM   #22
phillips's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Also according to the Reese instructions I saw it said front of TV should return to unhitched height or slightly lower.
Reese Dual Cam WDH
Old 06-04-2016, 03:11 PM   #23
WolfWhistle's Avatar
Like others stated, my old Reese was different and could be adjusted farther as far as tilt. You need to tilt the ball father toward the trailer / lower then you can have more free chain to allow you to bend the bars further. IMO
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-04-2016, 03:14 PM   #24
Look at your Ford manual as well.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-04-2016, 03:39 PM   #25
tjm
Pickups come factory with a rake. The back end higher than the front. For aesthetics some people put a leveling kit on it to raise the front end level with the back. This can also allow slightly larger tires. It gives the truck a more aggressive look. However as seen by the OP, this doesn't work so good with towing when you have a load pushing down the back.
Sent from my iPad using Tapatalk
tjm is offline   Reply With Quote
Old 06-04-2016, 06:10 PM   #26
phillips's Avatar
Thanks for the replies, I think I'm going to try using 4 links under tension and see what happens. I'll make sure I have the clearance to do this but from looking at some pics of other ppls setups who are running the Reese Dual Cam WDH it appears I have as much or more clearance then some who have 6 or 7 links under tension.
Reese Dual Cam WDH
Old 06-04-2016, 06:11 PM   #27
phillips's Avatar
I'm pretty sure of I can successfully use the 4 links it should give me that weight transfer I need.
Reese Dual Cam WDH
Old 06-04-2016, 07:46 PM   #28
Stormrider151's Avatar
If I raise the truck and camper tongue after hooking up I don't either. Not doing that requires the cheater bar.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-04-2016, 10:32 PM   #29
Have you weighed your trailer? You should be 10% heavier in the front than in the rear.
tomrob1161 is offline   Reply With Quote
Old 06-04-2016, 11:17 PM   #30
Professional Curmudgeon
Originally Posted by dirkpitt View Post
I actually just put the Reese dual cam setup on my camper. With 8 links hanging, I don't even need to use the bar to bring the chains up on the hook. Is this normal?
If the tension on your bars is low enough to snap the hooks up without a tool you are not redistributing any weight to the other axles. This means pretty much all the tongue weight is on the hitch.
Now, if your tongue weight is below the weight carrying rating of the hitch, you are good to go, if it is over, you need the WDH to move weight to the front and trailer axles.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
