Old 06-05-2016, 02:59 PM   #41
dbarr's Avatar
Originally Posted by phillips View Post
Nice to hear from someone who can relate to the same issue. Have you had any issues with using 4 links under tension? I know reese recommends minimum 5 links but I'm thinking I'm also gonna try the 4 links.
Sent from my SM-G900W8 using Tapatalk
Pulled it like that all last year, 5800 miles, with no problems. Bars cleared the trailer frame and rode nice. I wish it were on the 5th but it just doesn't work.
I wonder what the effects would be by lowering the head to the bottom hole and using a 1-2inch riser ball to gain more clearance from the trailer frame to bars?
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is online now   Reply With Quote
Old 06-05-2016, 03:01 PM   #42
phillips's Avatar
I'm not sure bit I've thought about trying it. If you look at the pic i posted a few posts back on this thread would you think I'll be pushing it for clearance once I move up to the 4th link?
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
phillips is offline   Reply With Quote
Old 06-05-2016, 03:08 PM   #43
dbarr's Avatar
3rd link the bars will make contact!
2014-47,
Years camping....52
Old 06-05-2016, 09:05 PM   #44
D-maxx dave's Avatar
Level
Just a thought, I have the "leveling kit" on my 3500 SRW. It tends to want to wander. Common problem I've read. Check front end alignment, that may help.
Dbarr, my bud bought a pickup with level kit, it was never mentioned by the dealer. Part of a package on the truck he bought.
Dave
D-maxx dave is offline   Reply With Quote
Old 06-05-2016, 10:09 PM   #45
dbarr's Avatar
This is what 4 links looks like. If you turn your chain brackets around in the correct direction the chains will hang straight down instead of forcing the brackets into the frame. U-bolt loop should be towards the frame.
Says the "desired" working range is 12-13 inches. I'm probably at 10 inches...never measured it.
2014-47,
Years camping....52
