06-04-2016, 02:44 PM
#21
Originally Posted by lbrjet
What is the point of lifting the front end? Never heard of that before.
A 1/4 inch rise in the front seems set up is pretty good, hardly ever gets exactly back to equal.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
So truck sits level front to back.
Sent from my SM-G900W8 using Tapatalk
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
06-04-2016, 02:46 PM
#22
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Also according to the Reese instructions I saw it said front of TV should return to unhitched height or slightly lower.
Reese Dual Cam WDH
06-04-2016, 03:11 PM
#23
Like others stated, my old Reese was different and could be adjusted farther as far as tilt. You need to tilt the ball father toward the trailer / lower then you can have more free chain to allow you to bend the bars further. IMO
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
06-04-2016, 03:14 PM
#24
Look at your Ford manual as well.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
06-04-2016, 03:39 PM
#25
Pickups come factory with a rake. The back end higher than the front. For aesthetics some people put a leveling kit on it to raise the front end level with the back. This can also allow slightly larger tires. It gives the truck a more aggressive look. However as seen by the OP, this doesn't work so good with towing when you have a load pushing down the back.
Sent from my iPad using Tapatalk
06-04-2016, 06:10 PM
#26
Thanks for the replies, I think I'm going to try using 4 links under tension and see what happens. I'll make sure I have the clearance to do this but from looking at some pics of other ppls setups who are running the Reese Dual Cam WDH it appears I have as much or more clearance then some who have 6 or 7 links under tension.
Reese Dual Cam WDH
06-04-2016, 06:11 PM
#27
I'm pretty sure of I can successfully use the 4 links it should give me that weight transfer I need.
Reese Dual Cam WDH
06-04-2016, 07:46 PM
#28
If I raise the truck and camper tongue after hooking up I don't either. Not doing that requires the cheater bar.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
06-04-2016, 10:32 PM
#29
Have you weighed your trailer? You should be 10% heavier in the front than in the rear.
06-04-2016, 11:17 PM
#30
Professional Curmudgeon
Originally Posted by dirkpitt
I actually just put the Reese dual cam setup on my camper. With 8 links hanging, I don't even need to use the bar to bring the chains up on the hook. Is this normal?
If the tension on your bars is low enough to snap the hooks up without a tool you are not redistributing any weight to the other axles. This means pretty much all the tongue weight is on the hitch.
Now, if your tongue weight is below the weight carrying rating of the hitch, you are good to go, if it is over, you need the WDH to move weight to the front and trailer axles.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
06-05-2016, 05:53 AM
#31
Seems like a trip to the scales is in order..... Maybe heavier bars? Not sure if they can be swapped out on that hitch.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
06-05-2016, 06:47 AM
#32
Should be able to swap bars out being its a reese. On my reese head I can run 500 bars up to 1700 bars . That's the nice part I like about reese over my Equalizer hitch.
06-05-2016, 07:01 AM
#33
The Big Issue if he can "put on the chains Without raising the TT/TV,or using a leverage bar" They have "NO SWAY CONTROL" at all! Let alone NO W/D! This is in reply to the "Piggy Back Post",not the OP! To the OP,since you Raised the 150 2" in the Front you are going to need "BIG BARS" to bring this all together for a PROPER setup or start all over with your Truck leveling Issues! Youroo!!
06-05-2016, 07:08 AM
#34
I'm not sure how you would go about figuring out how much the front of TT weighs vs the rear of TT? I know tounge weight shoukd be between 10-15% of total TW.
Reese Dual Cam WDH
06-05-2016, 10:05 AM
#35
Originally Posted by tjm
Yes the leveling kit will tend to cause your truck to sit nose high regardless of how well your weight distribution is set up.
Since it does look like the head is fully extended rearward, I wonder if the 2 inch receiver is level, or if the receiver starts out angled a bit with front lower than the rear?
I agree it looks like head is set at full rearward, yet it is not angled rearward. Maybe put level along the axis of the receiver and see if that may be a factor. Certainly sound like that should be a sufficiently heavy hitch.
Of course hitting the cat scale to be sure the tongue weight is not way too heavy would be a good plan. And I would forget all the fancy math and just out the tongue jack right on the scale pad to be most accurate.
06-05-2016, 01:23 PM
#36
Here's a better pic of my hitch ball angle. After looking at this pic let me know if you think it should still be tilted down more?
Reese Dual Cam WDH
06-05-2016, 02:46 PM
#37
Happy Keystone Owner
I don't have a leveling kit but have the same hitch as yours, setup just like yours, with the same problem. Not enough tilt back. I run on the 4th link at 800lbs tongue weight and 1200lb bars. My front TV axle comes in at 2880lbs. Almost equal to the unloaded weight. Rear is 2900lbs...about 760lbs heavier than unloaded.
Looks like your leveling kit angles your ball back a little more than mine does.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
06-05-2016, 02:48 PM
#38
No that is about Max "Rear Tilt"! Youroo!!
06-05-2016, 02:53 PM
#39
Nice to hear from someone who can relate to the same issue. Have you had any issues with using 4 links under tension? I know reese recommends minimum 5 links but I'm thinking I'm also gonna try the 4 links.
Reese Dual Cam WDH
06-05-2016, 02:54 PM
#40
That's what I have now is 1/4" higher in front then without TT hooked up.
I'm not sure about actual weight of TT . I know it's dry weight is 6000lbs, So I can't imagine the loaded weight being any more then 7500 lbs. My hitch is rated for 15000lbs and spring bars are rated for 1200 lbs.
This is the Pic that puzzle's Me,did you weld additional length on this head? It sure looks "NON Factory"! Youroo!!
